praveen.valluri
Export/import Contacts For Nokia
Hi alll
I want to export my contacts available on my Nokia 6275 cdma phone
Please help
Options are not available with pc suite
How can I do that?
regards
Praveen
Hey
so many experts
so many savvys in this forum
cant any one of you reply for my query
Is that not clear
Let me explain
I am looking for exporting the contact details persisting in my mobile phone with model number Nokia 6275
Generally we see this option in Outlook express or some email programs to import or to export contacts
Also Nokia provide pc software ie pc suite also not showing me that option.
So let me know if anyone knows about that
Praveen
You must have an option of syncing with MS Outlook in PC Suite. Use that to transfer the contacts to MS Outlook, and then you can do whatever you want from MS Outlook. In case you do not want to play around with your existing contacts in Outlook, create a new contact directory by the name of "Mobile Phone Book" and use it for taking backups and/or exporting phone numbers.
You can use Diego also .... quite easy there.
Hi alll
Please help
How can I do that?
regards
Praveen
hi, if ur using any reliance phone colour handset with R-World just go R-world in that u will find (More Serivices there you will (PhBk Trnsfer) then again click PhBk Trnsfer there you will find upload and download.
$alman
Edited by bondinginheaven
$alman
I think that will be charged by service provider in my bill
why should I go although I am having data cable and all
hey na
Any ways I am using My RWorld loaded handset with Tata sim
