somanna
Lg Rd 6600 Memory Card Unlock
Please let me know how to unlock the mmc card so that i can use it on the computer also to copy files to it
Which card it uses?Micro MMC, RSMMC or Normal Size
Edited by Mr_Flop
nothing u need to do!! only these simple steps will solve ur problem yaar!!
just put a small piece of tape near the lock butto of the adapter and make sure that that lock should not move upside down!!!
thatz it ur ready to copy any thing ....
My self Divya Dhawan I am also the user OF LG RD6600 if you want to download your mmc from your PC/Laptop Do these step
1;-Insert mmc in Mobile and copy all types of files to your mmc from Mobile, It will creat Defauld Folder & location.
2:-In the 'DCIM->100LGCAM' FOLDER YOU WILL FIND IMAGES AND VIDEOS IN THIS FOLDER YOU WILL LOAD YOUR ALL IMAGES AND VIDEOS HEAR
3*:-ALL iMAGES NAMED WILL BE IMG_0001,IMG_0002,IMG_0003IMG_0004..........(ALL ARE JPG FILES ONLY)
4#:-ALL VIDEOS NAMED WILL BE MOV_0001,MOV_0002,MOV_0003,MOV_0004............(ALL ARE MP4 FILES ONLY)
5$:-IN THE "USER-.MP3' FOLDER YOU WILL FIND ALL MP3 FILES LOAD YOUR ALL MP3 FILES HEAR
TIPS FOR TRICKS FILES
* YOU WILL USE " FREE IMAGE CONVERTER'S/W FOR CONVERT ALL IMAGES INTO SMALL SIZE. IF YOU WANT TO SAVE MAXIMUM CAPACITY OF YOUR MMC YOU WILL CONVERT YOUR IMAGES INT 176x176 PIXEL SIZE RD6600'S LCD MINIMUM SIZE IS 220X176 AND THIS IS VERY GOOD SIZE IF YOU WILL CONVERT YOUR IMAGES OVER THAN 176x176 THE IMAGES
WILL CUT THIS S/W ALSO GIVE A OPTION OF AUTO RENAME OF CONVERTED FILES AND YOU WILL NOW FREE TO RENAME OF ONE BY ONE FILES.
IF YOU WAN TO THIS IMAGES AS ALSO SLIDE SHOW U WILL USE ADOBE PHOTOSHOP FOR THIS, ANT THIS IS VERY EASY
OPEN ALL IMAGES IN ADOBE PHOTOSHOP THEN GOTO IMAGE->CANVAS SIZE A LETTER BOX WILL APPEAR NAMED CANVAS SIZE IN THIS BOX CHANGE WIDTH=220 PIXEL, HIGHT=176 PIXELS AND SAVE THE FILE NOW THIS FILE WILL BE
USED IN ANY OF LG RD6600 MOBILE FUNCTION BUT THESE IMAGES WIL WOR WHEN THEY ARE IN MOBILE.
NOTE:- IN ONE "100LGCAM" YOU FIL LOAD ONLY 995 FILES IF YOU WANT TO ADD MORE FILES YOU WILL CREATE
FOLDERS 101LGCAM,102LGCAM,103LGCAM,104LGCAM,105LGCAM, WHEN YOU CREATE 105LGCAM, FOLDER YOU WILL NEVER SAVE ANY VIDEO OR IMAGES IN YOUR MMC DIRECTLY BY CAPCHER FROM MOBILE. SO USE THESE OPTION CAREFULLY
# FOR CONVERT ANY VIDEO FILE TO MP4 FORMAT U WILL USE THESE S/W
1:-TOTAL VEDIO CONVERTER, 2:-YASA MP4 CONVERTER
AND USE THIS SETTING
VIDEO
FRAME SIZE:-220x176
FRANE RATE:-15fps
BIT RATE:-15
CODEC:- MPEG
AUDIO
FRAMERATE:-8000 B/S
BI RATE:-64Khz/64000hz
VOLUME=255
TOTAL VEDIO CONVERTER IS BETTER THAN YASA MP4 CONVERTER BECAUSE IN YASA MP4 CONVERTER
YOU WILL CHANG ESETTING FOR EVERY VIDEO AND THIS PROCESS IS TO LONG & BORAING
AND IN TOTAL VEDIO CONVERTER YOU WILL SAVE THESE SETTING ONE TIME AND SE EVERY TIME
$ IN LG RD6600 THIS IS A PROBLEM THAN THIS ONLY SUPPORT 200 MP3 FILES IN YOUR MOBILE+MMC
THEREFORE YOU WILL COMBINE MAXIMUM FILES OF CONVERT TO MP4 FORMAT, IF YOU WANT TO SAVE MAXIMUM CAPACITY OF YOUR MMC YOU WILL REDUCE THE SIZE OF MP3 FILES BY REDUCING BIT RATE OF MP3 FILES UP TO 48kbpb BY USING:-MUSIC MATCH JUKEBOX, ARIAL AUDIO CONVERTER, MAGIC VIDEO CONVERTER ect
SP NOTE:- YOUR AUDIO, VIDEO FILES ARE NOT LOUD AND YOU WANT LOUD SOUD FROM LG RD6600
BUT IN LG RD 6600 IT HAN NOT HEAVY AMPLIFIER SO U WILL AMPLIFY SOUND USING SONY SOUND FORGE.
iI HOPE THIS THIS INFORMATION IS SATISFID U HOW U WILL USE MMC WITH YOUR PC NOW U WILL USE YOUR MMC WITH PC N ENJOY. IF HAD ANY PROBLEM ADD A REPLEY IN YOUR THEREAD I WILL TRY TO HELP U
IF YOU WAN TO DOWN LOAD THESE S/W GOTO PHAZEDDL.COM DOWNLOAD THESE S/W FOR FREE
HAVE A NICE TIME
Thanku verymuch. But where we can find Sony Sound Forge to amplify this Mobile.
Ramesh Bhandari
User of LG RD 6600
Edited by Honest
<< Unnecessary Quote Removed >>
