hoodedracer
6700 Differences
what is the difference between the 6700 for the US and the one from reliance because i have a new 6700 in the US but i am coming the india and i want to sell it??? it also has windows mobile 6 custom rom by me :Riendo:
none except exended rom and ofcourse quality of hardware.
Kshah Bhai,
How hardware quality is different? No one will be specialy manufacturing for RIM.
In my view just Extended ROM seems to be different.
Kshah Bhai,
I dont know how they make different qualities but I have used PPC 6700 from verizon, sprint and reliance and reliance handset though it was hardly used has poor keyboard, keyboard slide and buttons.
If you compare two handsets side by side, then you will realize. I have seen this with even Nokia 6030, Motoroala and imate kjam too.
hi,
i second KShah on quality.
there's a difference in the quality of a same model of a particular manufacturer across two different continents. to give you an example, there's difference in quality of GSM handsets in Europe and those in India. typically, made-in-Japan is found in Europe and made-in-Malesia/Taiwan found in India. Same for digicams too.
