a_krishnam_raju
Avi To 3g2 Converter For Nokia 6265 Cdma
Hi! Guys
I want to convert AVI files to 3G2 format so that i could view video files on my Nokia 6265 CDMA phone. I tried using ALLOK and PLATO video converters but in vain. These applications are converting the AVI files to 3G2 but i am trying to view them on my mobile none on the video files (3G2) are working. My mobile show a message which says "Unable to View".
Please help me to convert AVI files to 3G2 so that i could view videos on my Mobile.
Will be waiting for your reply.
Thanks in advance.
Cheers!
Krishnam
Hi! Guys
Thanks in advance.
Cheers!
Krishnam
Hi Raju,
There is a site, where you can get the files converted freely and downloaded:
http://www.all2convert.com/index.html
If you want to convert any you tube videos, you can simply give the url of the video which the site will access, convert and give you as a download in 3GP format.
If you want to convert your own AVI videos, you can upload and get it converted to 3GP format.
If you specifically need a converter, then you can try the "Mobile 3GP converter" please check in google for its site, I forgot it.
:GirandoOjos:
Cheers!!!
Mohu
