aninda_d
Caller Tunes
How do I delete caller tunes (call back tunes) from My Library? When I fire up the app in R-World and press the delete button nothing happens. I have 6 tunes in my library, and these keep getting renewed. So i keep losing 90 rupees for tunes I do not want anymore. Any help would be greatly appreciated. I use Nokia 3125.
Aninda
i guess when u unsubscribe ur tunes are automatically deleted .......but still icheck and inform u
I unsubscribed by sending UNSUB to 51234, but I can still see the tunes in my library. I do not know whether the stuff will stop auto renewal or not. Can't I access my library from my web account with reliance website?
Aninda
To delete a callertune, type DEL <Tune Code> and send it to 51234 or 52345 as me not sure abt the no..
U can contact CC and they will let u know the procedure...
yep jatin the number is correct ..and it i free as well thanks for the info jatin
Thanks and regards
amit ghosh
Thanks and regards
amit ghosh
del <code> to 52345 is the correct way. However, since I unsubscribed already I get an error sms saying that "you're not a MyTunes subscriber". I suppose the auto renewal will stop now.
Thanks,
Aninda
Thanks,
Aninda
Great to hear that your problem got resolved.
Aninda
Hi Aninda..
this is Sanket from Nanded
i read ur problem..
do one thing jst go to ur Write Message Box - Create Msg - type LIB and send to 52345
u will get list of msg which contains details of ur Tune in ur Lib.
pls note all the codes and type DEL<Space><Code Name> and send it back to 52345
u wil get relief from tune list
I have copied the caller tune from my friend and due to this i recieve miss calls everytime coz they wanna listen to my caller tune !
Can you please help me how to unsubcribe it or rather delete my caller tune code in 536413(woh pheli..) Please consider my plea.
Thank you
