Code
Sending A Custom Ringtone Thru Mms!
How to do it(possibly) in RD 7130/7230
1.Save a Draft message from Ur phone thru R-World.
2.Open the file system in bitpim.
3.Find out which of the folders under ams directory contains the mms client.
4.Download the #D#R#A#F#T.db fle on to your desktop.
5.Open it with a hex Editor.
6.Select the Portion starting form MThnd to FF2F00 (hex) i.e the midi file enclosed there.
7.Create a midi file with the exact size (most painful step) in PSM player.
8.Open the midi in the hex Editor (another tab or another instance).
9.Replace the contents just highlighted(selected) in Step 6 with the contents of Step 8 midi file.
10.Save the modified #D#R#A#F#T.db file in the hex editor.
11.Upload the #D#R#A#F#T.db file back to the phone (using PSM player).
Connect to R-World-> MMS.
Select Send MMS select the draft message.
If all goes well U should hear Ur favorite midi file.
Send the MMS :)
EDIT: Found a serious flaw in this.
The midi sent will be from the url in the draft file.
I dunno how to make the link instead point to a local file.
Some one with RD 7230 can help here either by analyzing the #D#R#A#F#T.db containing a camera picture or posting such a file here for others to analyze.
Help :help:
Nope I want to get hold of a mms draft file (#D#R#A#F#T.db) containing a pic taken from camera (in 7230) so as to see how to link a local file.
Can some with 7230 send (#D#R#A#F#T.db) file ....
Nope - Unless I get hold of that file I don't think further progress is possible :D
Isn't this supposed to work on LG RD 2030???
I mean, what's the difference between the two sets as far as ringtones are concerned?
And both can send MMSs...
Correct me if I'm wrong...
Niket I checked that the file U sent has the midi modfied (Did U use a hex editor or Ur phone permits to do that ??)
I was looking for the draft.db files one with a local pic & NOT midi (one taken from ur camera) so that it can throw some light on linking local files.
Best Regards
I know __ I wanted that the pic be taken from the camera of the LG phone and NOT be picked from the R-World Gallery. By studying such a draft.db file one can get an idea how this local file is linked.
Now what niket has done is adding a custom midi file in place of the one from R-World - This works only on Ur h/s. When u mms it the recipient will instead get the mid that was originaly contained as the link still points there.
Hope I clarified it.
Code,
I modified MIDI with Hex Editor But Whenever I modify #D#R#A#F#T.db..
MMS Saved in Draft No Longer open in MMS Client In R-World so I conculded that
Some where In #D#R#A#F#T.db it saves header information about files stored in #D#R#A#F#T.db
So If we able to success fully alter that info it is possible to send modified MMS.
In following #D#R#A#F#T.db file photo taken from my phone is saved check that out. and only one mms is stored in this file with ringtone(it is "humtum" form Rworld) and photo.
pls do all you can..!!
Regards
Niket
_D_R_A_F_T.db
Thanks for the draft.db file. I will study it.
I remember to have successfully added my own custom MIDI and Pic and then opened it in the mms client. I used the MIDI and pic with exact same size as original (not even 1 bit longer or shorter) and it works*. But when I send it to some on the original one (not one I upped) is sent due the link pointing to the R-World file.
*It means the byte offset of Midi and png is stored some where in the header __ I am yet to find out where exactly. If we find out then we can prolly write a draft mms editor to add new midi/png using a GUI on our desktop and then upp it.
Lemme work on the local link stuff first :)
I have found out :)
It is a jpeg image 4.67 KB in Size.
Part of keyboard and mouse on a Table is displayed.
Now I want to know if that image it is stored in a folder : image/jpgc ??
If so what is it's file name? Is it 07 ??
Yeah code,
U got it.. nice dude.. even I am failed to find jpeg file in draft.. to find out midi is easy for me..
In my Photo Album it is named Photo002 but in bitpim file system I have to check its name(it's may be 07) .Today I am out side but when i am send draft next time i will post all possible info with that.
Thanks niket. I will wait for a new db file with all that info <_<
Locating the jpeg is easy as Static said.
