ACS
Reliance Launches Adm 100c Usb Data Card
Hi Guys,
I was going thru the Forum to find more about the USB Modem ADM 100C..
Looks like im gonna be the 1 introducing it !
Attached details in word file format, which i gathered from the WW sources..
ANYDATA_ADM100C.doc
Edited by ACS
Did they mention the price?
This is Chinese Model, ZTE and Huawei are much better.
Price Rs.2490 Same.
Price Rs.2490 Same.
@ Amit Jain
Your observation could be right as you may be getting market feedback being a WWE..
But on the basis of Chinese / non chinese is confusing..
All are produced in China right ?
Nevertheless, everybody seems fed up with the designs of ZTE 880 & EC 325.
This is simple. hoping that it also performs well as i will be buying it.
Hi Guys,
The software for this new data card is not good. Huawei was more stable and it shows the bandwidth which you are using.
These features are not there with ADM 100c . Moreover u have to connect it manually through dialer of windows. Even if you connect through connect button of s/w, it would automatically be disconnected.. i have tried it with both Windows XP and Vista. They need to improve their S/w.
There is no history in the S/w, how much you have download. So another money making idea :)
It doesn't show right data , how much have been downloaded and uploaded.
If somebody else is facing these problems, please let us know.
Regards,
Piyush
Strange..
Things should be improving here since other Data Cards are stopped after its entry.
This is not a mobile phone which Reliance introduces & throws it in the market to make money.
Tech ppl.. plz help in ratifying this issue.
Hey..
Check out their never ending list of service centres in each city/town/village.
ADM_100C_Service_Check_List.xls
Is my HPSMS-Server Version 3.5 can send SMS Somebody Please Try in GSM-Text mode and Report back me the Speed
Well, here are my observations:
1. AnyDATA modem is faster, very stable. Am using it on Vista.. Huawei never worked for more than 10 min continuous.
2. You can see total, monthly and last-session data transfer when you click on settings icon.
3. no need to manually connect from windows dialer. It works great with the AnyDATA CDMA Dialer software.
4. Do use netbooster, it really helps. Just remember to use the right level of boosting by clicking on the netbooster icon in system tray.
I'm lovin' it
Hey..
know what.. this is the only model where manufacturer is giving over-the counter replacement for a defective unit.. good gesture to begin with, at least. I waited for 10 days for my Huawei.. can you imagine 10 days on the road without internet!!
Price Rs.2490 Same.
@ Amit Jain
Very correct my dear Jayanth. Nearly all data cards are produced in China now a days.
You should go for this data card as they are providing over the counter replacement also.
Just go and get it. :)
The Chipset is made by Huawei and its the Same EC321 in Core
This data card dis-appeared much faster than it appeared..
Check out Post 8.. maybe thats the reason.
They packed off !
