vikrampustake
Not able to connect - NETCONNECT error 678
Hi Guys,
Can any of you help me for my samsung W619 , i am not able to connect R- Netconnect service , error showing 678 ( The Remote computer did not respond ) , I had contact to stupid customer care for help , i as hang for last 2 day this people are helpless and hopeless..Every time reply only dailouge ( WE HAD CHECK OUR END SETTING , AND REFRESH FOR UR MOBILE , IT SHOULD WORK , KINDLY TRY AFTER 3 HOURS ) ALL SCRAP.
I had check all the setting in phone modem + dailup connection every thing is perfect.But not able to connect. Any one had tryed plase share the exprience.
thankyou.
vikram
Ur modem is not properly installed.
and please avoid double posting.
<< post merged >> << Please do not double post >>
Dont worry, If all of your settings are ok from your end, then it is a small problem from BackEnd.
Call - 180030005555 and tell them problem,
They would escalate your complaint to Backend Office and your problem is solved.
