atulg
Problem With Lg Rd6100
the speaker of my RD6100 has been turned on permanently. so whenever i receive or make a call i have to turn off the speaker first.
couldn't find any phone setting related to this.
please help.....thanks in advance..
dunno specifically abt 6100
but faced a similar situation with 6600, it wasnt a problem but just a feature.
Solution : Long Press the button you use to activate speaker (generally the OK button) and the speaker will turn off for general use.
Reason: It happens whn you long press the speaker on button in standby mode, after this whenever you make or receive a call it is routed to speaker and not to ear piece
^^^ Hi Guys
Well As Per Described mine friend abhims that is true if that will wont work then check sounds settings from menu !
often it's happening when phone getting hanged that time only the settings cant retrieve !
you may do one thing also make mobile memory not fulfilled ! if yes then try to clean out like call history and sms's !
Regards
Shyam
yes this happens with most of lg phone . this solution is right
hello
guys
m getting problem in using my Lg Rd6100
the problem is..that while am on a call and whenever i get a call waiting i get my mobile switched off..
please help me out i need a solution
I am facing the similar problem on my RD 3510 handset.
From this discussion i see its solution as
But i did not get the details of it.
1. What is the button to activate the speaker ?
2. When should I press this button (during the call is on / call is not on)
Please reply as I am really frustrated with this feature ?
Sohan
its the ok button in middle of scroll
