zeemoo
"huawei Ec168c" Is Not Working With "win Vista Home Premium 32 Bit"
Hi all ....
i am using "HUAWEI EC168C USB Broadband Device" "EVDO" !!! i am having problem in my DELL Laptop model "DELL Inspiron . 1525",
Operating system Windows Vista Home Premium 32 Bit.
Device Mass Strage is working but My Laptop Hardware change is not detecting any new modem of "HUAWEI EC168C USB Broadband Device" i am unable to install the moden coz its not detecting by the laptop !!! :Decepcionado:
i have tride so many time to install the manual driver but if the Laptop is not detecting the Modem so how can he pick the Driver !!! i am very upset abt that !! its working ok on win Vista Ultimate 64 Bit, Win XP 32 Bit, but only problem i am having in my windows !!!
kindly resolve my problem !!!
Cheers
Azeem Shah
The driver issue occured in a Vista Machine but that was with the printer. HP printer was not detected by the machine, which was supposed to be detected automatically as per HP. The only solution I tried that to install the latest service pack (Vista SP1). When the machine rebooted after installation without any further intervention the machine accepted the printer and for last four months the machine is running fine. You also may try to install the latest updates and service packs, probably the problem may get resolved.
^^^^ Buddy Chiradip.. i didn't understand your point.
You want him to find new updates/service pack for this new HSD ?
i think u dont get me correctly ... my problem is regarding installing the Huawei EC168C Usb Broadband Stick ...
i am using Windows Vista 32bit SP1 .... i can use the Huawei EC168C as a Mass Storage Device but i am not be able to install
the Modem driver for broadband !!
i know one thing that if u download the Reliance Netconnect Software for this device coz u people know Reliance Netconnect are also using the same device as EVDO ... still i am getting the same problem !!! but one of my friend install the Same Reliance Netconnect Software for Huawei EC168C and its working well and also detect the modem !!!
my problem is regarding my Laptop is not picking the Modem hardware !!! i have tried so many time but :Equivocado:
i hope now u guys get my point !!!
Sorry 4 bad Eng !!!
i had problems getting my broadband [HSD] usb to work on my HP laptop with vista
WWE customer care spent 2 hours trying to get it to work and even uninstalled the data stick for the old [narrowband] data stick without any luck
after detecting the modem, i got it working by simply running in XP compatibility mode
now it works fine on my vista laptop...
One of my known person have same Dell Inspiron 1525 with Vista Home Premium 32 Bits.
I sucessfully installed Huawei 168c device driver in his laptop.
And Zeemo, I think I have grasped your problem, and I know the cause and solution.
Cause - You must be installing the Setup from .exe file by exploring the Huawei Ec168c Mass Storage Drive.
Am I right ?
Solution -First uninstalle any installation of this modem if avaialble in laptop then,
Dont run .exe setup file by exploring the USB Mass Storage Drive, Instead Click Autorun, Now it will pick the drivers for sure.
hai friend,
some time this problem accounts by anti-virus ,,,,so just disable your anti-virus still HSD installation finish.
Am I right ?
GURU Jee .... i am using EC168C in pakistan here worldcall telecom is offering CDMA based Broad band services !! when i try to install the EC168C through the software worldcall gave us i am having problem detecting 3G modem of my EC168C ....
finlay i have download the Driver setup of reliance EC168C so my windows is detected the modem or all required drivers and with out desktop icom of Mobile Partner it can also access.... but if someone having problem regarding this so how would i help them !!
i dont think dat its a good idea to install the reliance EC168C software as Worldcall EC168C ...
can u help me so dat can get the drivers files from it so dat my windows detect the modem driver !!!
both companies have the same setup size but still i dont understand which file is missing !!!
Cheers
ZeeMoo
