deepu
Problems With Skin Chooser
Hi Arun,
Have you noticed, there is some problem with the Skin Chooser. The Default one works fine. But if some one changes it , there are problems... like the banners not proper and all... Can you correct it..
There are only 2 skins in the forum. IPB Default Skin and Beachcomb. Both are working fine here. Beachcomb doesnt have Ads or Banners in it at the moment.
Changes to what skin ?
Why the skin chooser shows beachcomb skin twice?
I mean there r two same entries for beachcomb skin.
only the default skin works perfectly.
beachcomb skin is very ugly and useless.
Actually beachcomb looks good man. Look when its finished.
Arun need to sort out the buttons and stuff, and lot more...
heh heh...
But the skin as such is great. pleasing to the eyes ...
Actually what I meant to say was for the default skin...the top banner of rimweb.com is coming correctly... but for beachcomb this is not coming.
The default one looks nicer than beachcomb
18707[/snapback]
Fixed now
18742[/snapback]
Yes, I havent uploaded customized buttons or banners or logos in the beachcomb skin yet. Thats why they dont show up in it. And I do not plan to work on it either as I don't have the custom button/image set for it. The default skin is simply the best. :P
arun, tell me whats the use of beachcomb skin?
Why u d/l that skin?
there r so many skins for IPB.
I've seen many forums that use IPB and they hv gr8 skins.
So it'll be good to delete that ugly skins.
cauz its useless.
I haven't come across much good skins for version 2.0.0 of IPB. Many are paid skins. If you find a good skin (not a forum using a particular skin but a site which offers the skin for free download), then tell me. BTW, if you dont like the skin, then just don't choose the skin. Whats the harm if it is in the list ? I've noticed that some members are infact using beachcomb skin for the past few days.
I've no problem with the skin.
and surely if i find any site that provide some COOL skins, i'll tell u!!!
Forum Logo and AdBanner have been added to the beachcomb skin.
I have tested ion IE 6. Let me know if it works well on all browsers.
Now beachcomb skin looks better than previous.
Both logo and ad-banner working fine in Mozilla also.
GOOD work code!
Logo and ad banner are working fine code.. But the buttons stills need some changes.... Make the back ground of the Gif images used by buttons to transparent... That may solve the problem of buttons
deepu - One needs to make custom buttons. Making background transparent reduces the visibility of the buttons (blue against blue).
May be we can install another good free skin if available rather than doing this.
18917[/snapback]
Yes I will try to find some good free skins :thumb:
There are lot of new skins in the above sites...
Can u install those Arun??
invisionize.com is not loading for me.
only the home page of ibfstyles.com is loading for me
nbsdesignz.com's free skins aren't that great. They are mostly color variations only. They were installed in the earlier version of IPB at RIMWeb. Will try for a couple of them anyway.
right, working now
Vanila Cola is installed and working fine.. Great work Arun
Update: I just completed Installing two new skins Vanilla cola & Forum logic.
Also redundant entries under skin selector have been removed.
Thanks to Arun Deepu & Vishal.
Lemme know if any problems wid diff browsers.
Enjoy!!! :P
There is some problem with forum banner in "Forum Logic" skin.
both new skins r GOOD.
GOOD WORK code!
LAGE RAHO!!!
Edited by Vishal Gupta
Well the new skins look cool esp the forum logic
