Car Sub Woofer Car Sub Woofer
#1
Posted 19 March 2010 - 12:45 AM
I am looking for a Sub Woofer with great bass. Can anyone suggest one?
#2
Posted 19 March 2010 - 01:02 AM
1200 Watts of power with such a mean bass that too in unbelievable rate. 3000/=
Make sure you amplify it enough so that it could show you its capability.
Also get an enclosure for that made from double MDF board or the full enclosure with the acrylic on it which I prefer, it gives the max out of it!
Hope that helps. Lemme know if you have any further query, I am like a geek of ICE- In Car Entertainment!
Youtube Link:
This post has been edited by sumitvrma: 19 March 2010 - 06:49 AM
#3
Posted 19 March 2010 - 10:42 AM
My budget is 5K
Can u pls suggest a model for my i20
#4
Posted 19 March 2010 - 02:10 PM
Go for Pioneer Premier Series TS-3001 DVC D4, its around 6500.
But know what, to get this working, you need to spend 20,000/= to amplify it.
If it does fit your budget, think no further, its the best till now that I have given to my ride!
Keep the questions coming!
This post has been edited by sumitvrma: 19 March 2010 - 02:11 PM
#5
Posted 12 April 2010 - 05:29 PM
i was in search for a double din set
and concluded with JVC KW-XG500 @6.5K
or
kenwood DPX-MP5110US
http://india.kenwood...2din/index.html
pls suggest an entry level power amp. and Sub woofer
Total budget including Stereo is 14K
usb not necessary but shud hav aux
This post has been edited by FEVIN-RAJ: 12 April 2010 - 05:39 PM
#6
Posted 12 April 2010 - 06:12 PM
I have put creative 4 channel + subwoofer system in my friends car ... & the performance it gives is same as it gives as they are desktop speakers...
This is relatively a cheaper solution @ 2500 bucks .... but subwoofer sounds as they sound when connected to desktop.
If only your requirements are to hear in car & not out of car then this is a solution ...
Maulik
"Learning cdma stuff, sound interesting"
#7
Posted 12 April 2010 - 06:16 PM
There is nothing extra in there till you go for a DVD player that too with screen.
I suggest you go for Pioneer Series HU, I find DEH-P6050UB an awesome thing to have. Pioneer has the best output as compared to anything at this price.
You could go for the Chinese Amp (Sorry, but thats what gonna suit your budget and are good aswell) Sound Barrier or Alpine ( not the Genuine one )
Use Pioneer TS-307 D4 DVC as a Woofer with the Acrylic Enclosure. ( Gives a mean as bass )
NB: Use the Genuine JBL Amplifer Kit with the RC leads.
Lemme know If I could help any further.
#8
Posted 13 April 2010 - 12:30 AM
thanks sumit
old i 20 magna comes with factory fitted 2din stereo
when they introduced the cheeper variant (i20 era), they removed the 2 din and kept the space vacant
single din would not match for the space vacant
thats y i planned a 2 din set
hows this JVC products ?
the shop owner will give 1 year service warranty
DEH-P6050UB is little heavy for my pocket
pls suggest a 2 din for 7-10K
#9
Posted 13 April 2010 - 12:37 AM
Go for Pioneer FH-6050UB (without warranty, Trust me you wont need if you care)
BTW, You can get an additional fitment, which will allow you to split that space for A single din, and the left over space as a mobile holder
Pioneer Is what I like. Had one bad experience with JVC so, I ditched it forever!
Dear Mods: Kindly Change the topic name to " ICE: In Car Entertainment " if possible.
This post has been edited by SumitVerma: 13 April 2010 - 12:55 AM
Help
