keks22
How To Unlock Phone Memory in Nokia 6275?
Hi Friends
I want to take a back up the contents of phone memory of Nokia 6275, but it says phone memory is locked,
I dont remember I have given any password or locked the memory.
Can you please suggest how to unlock it?
Many Thanks in advance
how u r taking phone backup ?
Nokia PC Suite should do the job.
I am taking back up using Nokia PC Suit Only,
while backing up it says
" Your phone contains copy right-protected material, which cannot be included in the backup, Click OK to Proceed."
using diego tool u can get ur unlock code
Try this Go to Menu > Setting > Security Setting > security level and Choose None if ask for code enter 12345
Tried it already but no luck... :( thanks for reply anyways :)
I got installed diego successfully, can you please explain where I can get the code. :signthankspin:
This applies to the ringtones and screen savers which are copyrighted. I never bother. PC Suite gets the rest.
ok that's great news. Thanks
