Followers 0
SUDYEcaZ
Best Roaming Plan
14 posts in this topic
Which is the best Roaming plan available for CDMA prepaid....
Currently my call rates are 0.50 Per min and SMS 0.01 per sms..
Can i get some thing better...as i m going to spend a month in roaming...
and most of my outgoing calls are on reliance network...
Does nightcalling pack "BrightNight"
or Unlimited calling works in Roaming
Yes bright nite works on roaming so i suggest you to use it and enjoy free r2r during night and 25paise other network. It works on roaming i have used it on 2 occasions.
you can shift to 995 plan for one month and take back ur old plan after your at ur home place. in 995/- u enjoy free incoming from any network, free outgoing calls to Reliance (CDMA+GSM+FWP) all over india while in roaming also, u also get 995 sms free to reliance mobiles cdma network while in roaming also, ur std will be 1/- and local will be 50p same is applicable while u r in roaming, the roam place where u go becomes local for u so in that place if u call somebody then u ll be charged locally i.e. 50p but outside that state u ll be charged 1/- to offnet calls :)
this plan sounds good, never knew tht there is any such plan in RCDMA..
dude he is asking for prepaid and 995 is in postpaid
in reliance default plan 1p per sec is the best roaming plan available
Even I was about to migrate to this plan as I'll be in roaming area for 6+ months but the offnet std calling rate holds me from migrating to the plan. Even after paying 1K bux STD call rates is 1 rupee.. :(
Go for 1p/sec plan with 1p SMS and add Bright night pack + 20p/min Local/STD/RoamLocal/RoamSTD R2R STV for Rs88/30 days also.. Then R2R calls will be 20p/min in day time, FREE in night.. Offnet and roamIncoming will be 1p/sec during day and offnet outgoing will be 1p/2sec during night...
Best Prepaid roaming plan ever... :)
Thanks for all suggestions :)
does Unlimited calling @ 599 works in Roaming
Edited by SUDYEcaZ
i am a delhi reliance gsm customer... i heard from cc executive that 50% discount on offnet calls in bright night pack has been removed... now they are charged 1p/sec even after 11pm... is it true???
Edited by iammanuarora
In roaming unlimited calling won't work. Calls will be charged as per your base plan.
Don't know about that.. But the official web-site is showing otherwise here..
i changed from 995 to 1pps... now my monthly bill is almost half.. earlier my bill was in the range of Rs. 1800 to 2000 and now its between 900 to 1050...
besides, for 995 imagine amount of call u can make by 1pps.. i did lot of calculation b4 chaning the plan..
Indeed a good plan ...mate .... :) thanks i will also have the same now ...
I also heard from customer care that 50% discount on brite nite pack has been removed. Is it for delhi only or pan India can any one confirm?
Followers 0
