harismahesh
Please suggest a mobile without camera
Hi...all..My friends needs a help...He recently moved to a new IT company where he cant use Mobile with Camera phone. So he is looking for a cute phone. He dont like Blackberry types and MAXX, MicroMax types. He is looking for a cute slim handset. MAinly trying for some thing upto a range of 10k.
Please help him !!!!
1st you need to tell your friend wants CDMA or GSM.
also in case of camera you left with very few options
Very sorry...he needs a GSM phone !!!!
Even from outside also is ok !!!
Edited by harismahesh
Go for low end phones as all high end ones have cam
Try LG GB 125, nokia 1800, guru samsung phones, nokia 2323 classic
Well... very few choices are there nowadays, if you want a decent GSM phone without Camera (other than Blackberry) for example Basic handsets from Nokia, SE, Samsung, etc..
I suggest him to go for BB8830 (either GSM or Imported CDMA with GSM Unlocked as sold in our forum by Gurus).. Else going for budget phones is the only way..
I have a good condition BB8830 for sale, if it interests your friend.
u have to opt for basic phone as most phones above 5k has camera.. there are couple of nokia phones as they will look nice compare to LG..
Advice him to go for BB 8830; he cant get such a high standard phone at this price. He's making a mistake by not going for it...
:previous:
agreed 100% with Dhiraj Bhai.
If your fren is worried about Govt. banning blackberry services then tell your friend that Govt. not going to block Mails and Voice calls. its only the Blackberry Messenger which they will block if Research in Motion(BB manufacturer) does not comes with a govt. desired solution.
He already said no BB !
there was one model in SE, which was having symbian 6 , touch screen + mobile keypad, + 4gb internal memory + NO CAM,
more specs here http://www.gsmarena....n_w950-1443.php
my brother is using same phone, good build , good quality, and still working after 2 years.
you may not get this phone in store, look for used one.
UPDATE :- If you want this phone, i can provide you for 12500/- (imported one)
Edited by ::Hitesh::
^ The best option for phone w/o camera is definitely BB 8830. Anything else will be very basic and useless. He should try out the BB 8830 in hand and reconsider his decision.
Otherwise only option for good phone w/o camera is to put a BIG STICKER on the camera in any good handset. :Contento:
^^^Hiteshbhai ka suggestion is awesome..
I have used Sony Ericssion W950
Sold it 3yrs back
Awesome phone,
I had sold phone because it was not having camera
i had bought from indiatimes.com at that time for 10500/-
when market price of that phone was around 24000/-
Brand New with lance tape intact , with head phone, charger, data cable,
:previous:
Yes, Hitesh Bhai.. I too remember that handset..
This was entertainment focused handset and another similar handset was released for business users @ the same time with qwerty keyboard and model number is M600
Features are ditto to w950, except the presence of qwerty KB, in which 2 keys are joined as one button.. Means "QW" is found in one button and if you press that button's left corner, "Q" will come and if you press the button's right corner, "W" will come.. (Means NO NEED TO PRESS TWICE the key for 'W' like in NokiaE55, a half-qwerty device)
Edited by KanagaDeepan
3 more difference
1) key pad is flat in W950, and in M600 its little lifted up.
2) internal storage in W950 is 4gb and M600 only 80MB
3) W950 no SD card slot, M600 SD card up to 4gb
but over all both are look a like phones
there is a new launch samsung champ without camera
model 3300
price : around rs 3400
touch , no keyboard , 1 gb card , bt , mp3 , 8gb card expandable , 1000 mahp battery , mobile tracker , facebook , myspace , flickr , orkut , picasa
similar phone you may say . it comes in two variants with n without camera both new launch
champ with camera model 3303 : price rs 4100-4200
champ without camera , model 3300 : price : rs 3500-3600
I have also worked at a facility which was a no cam, in this ppl. generally do possess a high end handset but while entering they either deposit in their locker/ security and use a basic phone inside the facility.
The requirement it seems is for a basic phone with attractive design and slim and thus light weight to carry around, blackberry looks attractive but could prove to be bulky
then i think  champ will be the best choice for without cam, and supernova can arrange it in india, so i think he should go for it.
does w950 really have 3G?
for phone without cameras?
:previous:
yes  :Riendo:
