Reliance Mobile - Discussion Forums
rajkum1972
Is It Possible To Use Tata Photon Plus With Android Phones?
rajkum1972    0
Hi all, Is it possible to connect tata photon plus with android phones to access the net? if any kindly let me know
shanusmarty    29
^^^ u can buy a new open market handset with evdo and android and activate ur photon plan on dat number !
rajkum1972    0
Can u name a few handsets that are available in india with evdo which support android os. Also i have a samsung galaxy s, and a photon plus usb modem tell how i can access my phone to the net with it.
shanusmarty    29
^^^ u need to get a android cdma fone . look into forum u ll get it.. n den take a tata indicom connection on dat fone to use evdo on dat fone..
Edited by shanusmarty
Mufaddal    678
there is no such information available on forum
u cannot use ur photon plus modem on android phone normally ( pun intended)
anyways mail me
i can direct u in right direction
commonman    207
TATA Photon Plus Mobile EVDO postpaid/prepaid is officially available on the following handsets with offer of 2 GB for 550 per month
* Samsung Corby TV
* Samsung Metro
* BlackBerry Tour 9630
* LG 510 Cookies Zip
* BlackBerry Curve 8530
http://www.tataphoton.com/tata-photon-on-mobile.aspx
Edited by commonman
shanusmarty    29
anyways mail me
hey! Doc sir! i tried to say dis only.. dat he has to take a new connection on android based evdo handset!
anyways.. Doc is a genius!
::Hitesh::    1,761
Just purchase a picket wifi router from tata photon +
and you can enjoy evdo on your phone (with wifi on phone), that to 5 phone or device at one time.
tarun_kabra    203
Is it possible for MTS MBlaze also? What exactly is this Picket wifi Router?
Regards
Edited by tarun_kabra
Dear Tarun
say a net add some days back
It is a wierless Broadband Router same like the tata photon +
a little larger in size but the same supports upto 5 Units connections.
Tata Photon Wi-Fi Pocket Routeris a revolutionary new wireless Internet access device which enables multiple users and devices to share wireless Internet access and stay connected on the go.It is a Wireless router with Internet connection on the move. The Tata Photon Wi-Fi Router allows broadband Internet access speeds up to 3.1 Mbps (downlink) and 1.8 Mbps (uplink).
This Wi-Fi pocket router is supported with an in-built battery for 2.5 hours of seamless operation and sports a RJ45 Ethernet port for local area network (LAN) support
More Details here
dont know about the availiblity of the same with MTS , mostly it is no it cant be used. but u never know with all techies arround
Regards
Edited by neerajayshree
