kshah
Ndrive 10.1.15 (1147) H With Maps
Yes sir i want it
Install .APK from here
http://www.zshare.ne...940281962a04c4a
Installation
NDrive-10.1.15-androboost.apk
1 Install .apk
2 Run NDrive to create the NDrive folder on the phone and cancle any downloads!
3 Copy over maps you have downloaded before hand to folder SDcard/Ndrive/Maps.
4 Run NDrive again and download voice packs
I will suggest Wifi as it will download 150 - 250 MB of data.
Maps here
Extract EXE and Copy the .map file to the folder Ndrive/Maps on your phone SD card
Enjoy off line navigation.
Edited by kshah
  • Like 7
Thanks Kalpak...
I am trying to install the apk from the phone, its telling
There is a problem parsing the package
is there any otherway to install the .apk file
Try again downloading the apk and then install.
Edited by phonegeek
there is a new version of map my india also for android
which works with sygic
i love google navigation so much that i have forgotten of offline navigation
but offline navigation is very handy when u cant use data ...so its a must have
True, but offline navigation is helpful in many many areas and voice navigation is very helpful on highways. Does google navigation works in India?
as if u didnt know
googe navigation works with brut google maps all over world since last so many mnths
Thanks a lot kalpakbhai.. Would be very useful when travelling inside AHD.. Last time I was lost in 132ft ring rd going to airport.. my guest had to wait 15mins until i came there to pick her up..
I hope the offline maps is the latest one??!!
Rastey bhi poorane hai, so dont worry, even if maps are old. :GirandoOjos:
as if u didnt know
Brut once worked. Later it stopped on my hero. So later I never bothered to try. Else would have not asked such question.
Thanks a lot !
Edited by gaurangbhartia
@kshah - Works great with EPIC... U have made my device more rocking than ever...
Chalo koi to khush hua. Any way which clock you use on epic? I want it.
Shah sahab,+1 lelo,software dedo, j/k,
wud appreciate if u can share wid me too
downloaded the maps says its corrupt.. anyone else installed succesfully?
thanks a lot.
re download
try using a download manager
Its called Fancy widget; I have placed the apk here - post #2
Dkji naam bhi acha dhundh liya FANCY widget. Thanks
Edited by kshah
downloaded 2 times. with download manager only .. not possible without that. both times it says
Extracting maps\ExtraFeaturePaks\INDP.zip
CRC failed in maps\ExtraFeaturePaks\INDP.zip
The file "???" header is corrupt
on the computer
Its off line navigation software So If any one wants it do let me know.
http://www.ndriveweb...cts/product/96/
Thanks KShah, Keeping in view the size of map files it seems that it will better that Sygic Map my India maps.
Just Downloading, hope it gives something more than Sygic.
+1 for You.
extract the INDP.zip to extract the map file mere bhaiyo... and use that 1 file only...
