rajanmehta
Motorola Launches Droid 2 Global On Verizon
Motorola has silently launched Droid 2 Global on Verizon Network.
Going by the specs and features, looks like a crown jewel of the Current Android Smartphones.
Specifications:
ANDROID™ PLATFORM
Android 2.2 (Froyo)
PROCESSOR SPEED
TI OMAP 1.2GHz processor with Dedicated GPU
MULTIPLE NETWORKS (It's a World Phone)
WCDMA 850/1900/2100, CDMA 800/1900, GSM 850/900/1800/1900, HSDPA 10.2 Mbps (Category 9/10), CDMA EV-DO Release A, EDGE Class 12, GPRS Class 12, HSUPA 5.76 Mbps
CAMERA
5 MP
FLASH
Dual Led
VIDEO CAPTURE RATE
DVD quality (720x480p) up to 30 fps capture; up to 30 fps playback
WIFI
802.11 b,g, n
QWERTY KEYBOARD
DISPLAY SIZE
3.7-in.; WVGA (854 x 480)
Supports up to 16M color
MEMORY
up 8 GB on board, 8 GB microSD pre-installed
REMOVABLE MEMORY
supports up to 32 GB microSD
Specification Link on Motorola Site http://www.motorola....lobal-US-EN.alt
Specification Link on Verizon Site http://www.verizonwi...iceCategoryId=1
Edited by rajanmehta
Wow that going to be a gr8 phone, but is it possible to unlock gsm part
wow :Sorprendido:
Koi ise bhi Rimwen par lao.
r u ready to spend 25+ for this ??
I m ready if it is worth it, you better decide the quality & build of handset,
I am in for it.
Very nice phone ... does it have a secondary camera ? .. Otherwise how will we do video calling ?????
I don't see a secondary camera in the specs.
It doesn have a secondary cam.neither did the first droid too. donno y they dont integrate a secondary cam
It has exactly the same specification as Droid Pro
Differences ::
Large Display (WVGA Vs Pro's HVGA)
Higher internal Memory (8 GB Vs Pro's 2 GB)
Higher processing power (1.2 GHz Vs Pro's 1 GHz)
Edited by kesav
Motorola DROID 2 Explodes in man’s ear in USA
http://news.cnet.com/8301-17852_3-20024611-71.html
Imagine you just bought a new phone 2 days ago and suddenly when you are using it , you hear a noise and then blood starts running down your face. This is what happened to Aron Embry from USA.His brand new Motorola DROID2 exploded in his ear and he had to be hospitalized Luckily no hearing loss occurred and he received 4 stiches due to the shattering of the glass in his ear.Surprisingly the phone is still working and can receive calls. Normally we associate phone explosions with battery misuse but in this case the battery inside the phone is intact. The real reason for the explosion is likely to surface only after investigations are conducted. Here is what Motorola had to say about the incident "Motorola's priority is, and always has been the safety of our customers, and all Motorola products are designed, manufactured and tested to meet or exceed international and local standards for consumer safety. We will reach out to the consumer and investigate this thoroughly.” via AndroidCentral
^^^ publicity stunt
Motorola droid 2 pro or global is primarily cdma handset and in cdma video calling is not possible till rev B is implemented so despite epic 4g having front camara its not capable of video callin on cdma.
^^ Yr correct, but what if I want to do video calling using Skype !!!! Moto should think such a small thing .....:(
Can anybody tell me whether this handset is dual standby or not ?
its not..
sent from my AnDRoid6300 using tapatalk...
^^^ Then which are the GSM + CDMA dual standby handset available on Rimweb ? Who sells it ?
None of them are dual standby. They are cdma+ gsm auto switch or any one.
droid pro is listed for sale by Hetal and I have listed droid 2 global in buy and sell bazaar. Both are excellent phones. Moto are not prefered by geeks because of locked boot loaders. Else excellent hardware in terms of specs n robustness.
Sent from my DROID2 GLOBAL using Tapatalk
Just found out from http://www.rimweb.in/forums/topic/28982-dual-sim-motorola-android-phone-coming-to-india/page__st__60 that Nitin has bought Moto XT800 a dualt standby. He was also abel to root it with http://www.addictive...al-androot-app/.
How is XT800 ? Plz. bring XT800 to Rimweb.
XT800 is available in market and online portals, so its of no use to bring that on Rimweb..
http://www.naaptol.com/price/705524-Motorola-Milestone-XT800.html
http://www.letsbuy.com/motorola-milestone-xt800-p-14600
here, on rimweb, we are craving for the handsets, which are not available in the local market, and some great gurus like hetal bhai, hitesh bhai, sadikk bhai, tushar bhai, are getting 'em for us.. :)
Ok.. Agree.
But then Rimweb needs some CDMA+GSM dual standbys. Probably with 3G and EVDO. The Gurus should bring some for the Aam Janta.
true.. it is very much required.. but other than chinese (low grade) devices, who else manufacture the same..
motorola too came up with dual sim, dual standby XT800, primarily for chinese market..
please suggest some real high end cdma+gsm (dual standly) handsets, with 3G & EVDO both..
NOne Exist till now...AFAIN
