kesav
ASP-518 -- Dual Mode Dual Standby EVDO Handset
ASP-518
There are 2 flavors.
ASP-518S (Android 2.2)
. Dual Standby, Dual SIM
· Screen: 480 x 800 WVGA TFT
· ANDROID OS 2.2 (Froyo)
· 5 Megapixel camera· 4GB RAM, 4GB ROM
· Call Time: 200min Standby Time: 120hr
http://anydata.com/handsets.php#handset0
ASP-518C (WM 6.5)
Operating System Windows Mobile® 6.5 Professional
Radio Frequency CDMA 800MHz, GSM 900/1800Mhz Supported
Data Rate EVDO Rev.A 3.1Mbps(DL) / 1.8Mbps (UL)
Input Type 3.2” Touch screen LCD
Dimension 108 mm (L) X 56 mm (W) X 14.5 mm (H)
Weight 130g with battery
Approval CE,USB compliance, RoHS
- Ultimate sleek design and high performance Windows Mobile 6.5 Pocket PC Phone
- Wide range of connectivity option (CDMA 800Mhz GSM 900/1800Mhz, WiFi, Bluetooth, GPS)
- EV-DO Rev.A, fast data rate up to 3.1Mbps
- Large 3.2 inch TFT touch screen
- Ultimate multimedia experience by Windows Mobile player and Dual Cameras(5M A/F + 0.3M)
- Micro SD Expansion slot for maximum data storage
- Simultaneous dual SIM(CDMA/GSM)
http://www.anydata.co.kr/English/product/view.html?code=any_Eproduct&section=6&section2=&slide=select&code2=&page=1&number=102&keyfield=&key=&outorin=
http://pdadb.net/index.php?m=specs&id=2283&view=1&c=anydata_asp-518
Edited by kesav
AnyDATA is an OEM. They manufacture for other brands, Carriers. Don't sell phones under their brand. Actually not well known for phones, mainly specialise in modems, routers etc.
The ASP-518C (WM 6.5) was displayed by AnyDATA at last year 2010 Mobile World Congress. Subsequently Philips launched it as Philips D908 in China market through China Telecom. It is available in China for about Rs 31,000. See this page http://www.hicdma.co...ail_300335.html
ASP-518S (Android 2.2) seems not to be launched anywhere. Rumour is that it will be displayed in this year Mobile World Congress starting from 9th Feb..Then some brand, carrier has to show interest and market it under their name. Quite a long road it seems if at all it appears here in India...
Good info rajan, your data digging capablity always amaze me. That's why I named you cid lol. I can't give +1 from tap talk you, but you got it for this one bro.
Sent from my GT-P1000 using Tapatalk
:previous:
I second it Genius.
May be Rajan is better than CID. May be we can tag him 'CBI'........I think 'RAW' is more suitable... :winko: :winko:
@Rajan, thanks for keeping the threads updated with latest information from reliable sources.
:clap: :clap: :clap:
