orhb
R-connect Login Procedure
So Guys i am on r connect connection through LG RD 5130 set.I am using a serial port Cable (Genuine) from r world.I had to install LG RD 2230 com Driver for that but it is working fine .Showing a speed of 115Kbps .Getting average speed of 8Kbps and download speed of 18 to 20 Kbps(In Opera v7.52).
My question is i am using my user name and password only the fone number and not with the STD code .Earlier in prepaid i used to connect using my STD code followed by my fone number.
Though i am connected is this the right procedure ??????????? :lol:
R-Connect Rating ****1/2
Just use your 93 number as the username and password.
93 level & plain old SDCA level works for R Connect (those got their nos before 93 level.
But it's advisable to use 93 level no. as user name & password.
One piece of information, the latest rconnect software bundled for Cordless USB got a better user interface while connecting with different service providers and you can disable rconnect dialer automatically launching IE.
