Help Needed - The LED / LCD / Plasma Paradox
#1
Posted 21 July 2011 - 11:00 AM
I need a 32 or 40 inch TV for 1 room and 46 or 55 inch TV with home theater for another.I want to keep the brand of both the TVs same to get proper discounts and services.
I've shortlisted Sony or Samsung LED for these but am thoroughly confused where what would be appropriate i.e. LCD/LED or Plasma and is there any other brand i should consider. Also I'm planning to use Tata Sky HD+ with these TVs so pls suggest accordingly.
Awaiting your suggestions.
Thanks in advance.
#2
Posted 21 July 2011 - 03:15 PM
samsung has many LED TVs and price varies as per series. They have full LED TV while sony don't. I will suggest go for Samsung. you can also ask Dhiraj. He has samsung LED, i guess 6 series.
In India, everybody will suggest you sony without any guess.
Edited by csmart, 21 July 2011 - 03:16 PM.
#3
Posted 22 July 2011 - 10:44 AM
what if the service is annoying for any reason on one of the TVs?
you are stuck with the same aggravation for the other one also
just go on the basis of final discounted price for both to see which combination gets you the best deal
many shops may discount additional if you buy both TV from them regardless of the brand
tata sky will work on any of the brands you mentioned so that will not be a constraint
if you have the budget go for LED
else go for LCD
i have a 32" LG plasma and the 'ghosting' is very visible when you power off so avoid these
also some power component tends to burn out unless you remember to switch off from the mains which can cost rs. 6-7 k to replace
our was replaced after 15-18 months of purchase and the warranty is 1 year as usual
i don't have to worry about this issue on my older panasonic LCD which has been used twice as much without any burnout
- Mark Twain aka Samuel ClemmingsA specialist is someone who knows more and more about less and less until he knows everything about nothing.
My handsets:
LG FWP
Motorola C131
Coolpad
#4
Posted 22 July 2011 - 02:44 PM
The think is that my family members are a stuck on SONY coz of the legacy and thus are aversive to Samsung but if Samsung's are considerably good than I can convince them to change their opinion.
Any further info would be great from members.
I've also been told by a very learned source that 80% of the components in Sony are from Samsung so I'm a bit perplexed about it ..... more infor or help needed !!!
Thanks in advance.
#5
Posted 22 July 2011 - 03:52 PM
My 40" Samsung LED TV 40D5000; Now your choice should depend upon your budget and the picture quality. Now for picture quality trust your eyes only, dont go by previous reputation.
I went for the LED because I got it for the price of a LCD (44K) because I went for the grey market one and not the warranty one. Its been 6 month's now and its going great. Just remember to give it a proper Voltage Stabilizer. I use my Microtek 800VA UPS for my entire HT system, to protect it fully. Now I dont say what suited me will suit you too. My mental framework may be different from your, and you may require warranty for peace of mind. I saved 30k and was willing to take the risk.
Now all top brands are good, whether Sony, Panasonic or Samsung. Decide your budget, go and see the picture quality, and take your decision. LED's are much brighter and crisper than LCD's. In plasma only Panasonic is good; dont even think of any other brand in plasma. But they are power hungry, a little old technology, but still give the most natural picture in large sized tv's (above 40"). But once you see a full hd movie in a good LED, I dont think you will like any other tv (budget permitting).
Edited by dkaile, 22 July 2011 - 04:13 PM.
Sprint Samsung Galaxy SII - Epic 4G Touch - The Mammoth Review: Samsung Google Nexus-S 4G From Sprint - Curvy Babe
Sprint HTC EVO 3D - World's 1st (Proper) 3D Phone Lets Discuss the Good/Bad, ROMs, Upgrades, etc.
Sprint Samsung Epic 4G - The Beast Is Here! Lets discuss the good and the bad, roms, upgrades etc.
Must Have Android Applications On Your New Android Phone Must Have Products for your New Android Phone
My Latest Hardware Purchase - Why? Cost? WebLink?
Verizon Htc Incredible - The Beefed Up Cdma Nexus 1 Lets discuss the good and the bad, roms, upgrades etc.
Nexus One Gsm Unboxing + Dock India Premiere
Sprint Htc Hero - The Latest Android Kid On The Block - Lets discuss the good and the bad, roms, upgrades etc.
Lets Discuss Wwan / 3g Networks - Connected Mobility Solutions
Sprint Htc Touch Pro - Problems & Solutions Radios, ROMs, Softwares, Updates etc. etc
Build A Full Fledge Core2Duo Windows 7 PC For Sub 25k, Windows 7 RC1 is now free till 31st March 2010
Sprint Mogul Latest Basic Rom 3.56.651.0 Radio 3.42.02 - Discuss Your Problems/Solutions Here
All About Treo 755p - Lets Discuss The Good And The Bad Google Sync for Major Devices
Movies - That You Loved And Would Love To Share With Others News Snippets Just Thinking
My Postpaid Plan is Simple PPS 199 + 11/- SMS1P + 25/- RWorld Plan Charge; Follow me on Twitter - dkaile ; Follow me on Google BUZZ - dhirajkaile SMS me on KIK - dkaile
My Feedbacks Leave Feedbacks for me here (click on Feedback - Leave Feedback) - http://www.rimweb.in...r/18748-dkaile/
Current Equipment List - Skoda Superb, Toyota Fortuner, Sprint Samsung Galaxy Note II, Samsung LED 40" 5 Series UA40D5000, Playon DVR HD 76120 with 2TB WD HDD, Tata Sky+ HD PVR, Yamaha RX-V457 6.1 AVR, NEC VT460 Projector, Dell Studio 15, Logitech Harmony 525 Universal Remote
#6
Posted 22 July 2011 - 05:15 PM
If you are looking @ pure color quality alone, then go with Sony high end LED TV's.
LG LED also had good color reproduction, but the biggest problem for me was its glossy screens(2010 models, not sure now).
I have been using Sammy 32c6900 as monitor,
Once you have adjusted with LED u will never go back to LCD.
As someone told in this form, plasma is also good, but best for big screens.
Edited by ss_rakesh, 22 July 2011 - 05:20 PM.
#9
Posted 20 August 2011 - 11:02 PM
#13
Posted 26 September 2011 - 07:13 PM
#15
Posted 01 October 2011 - 01:22 PM
One more point to keep in mind is to buy one with a high refresh rate. Normally lcd and led have a refresh rate of 60hz. Go for one with a refresh rate of atleast 120hz. With this you will be able to watch 3d movies via a 3d bluray player or power dvd 11 via a pc using normal 3d glasses like the ones we get in the movie theaters
I agree.. Guess most models upto Series 6 in Samsung offer 60Hz only..
Can it be configured for higher refresh rate like we do for computer monitors?
and... with Webos 2, Pre rocks too
