dranzer006
Changing Number on Palm Pixi +
hey guy am using palm pixi plus with reliance cdma and wanted to know is there anyway to change my current number ?
i want to use new reliance number on the same phone
if i did RSN change to transfer my current palm number to sim will i need to re-register my meid ?
please tell me know the detail process
thanks
IMO Once your MEID is registered with RCOM, you can change numbers like with any other CDMA handset. You can either use a HCC (easiest way) or through the Rworld
Transfer ur no
Raise lost and found request for pixi
Its ready for new no.
well you see HCC cards are not available anymore and raising phone lost request will take atleast to 2-3 days, is there anyother quick way ?
if you use HCC then you can transfer new number to pixi without any trouble, if hcc is not working then genius way is right way
