nayasaroj
Reliance GSM Codes For Checking Various Details
13 posts in this topic
  • Check main balance & validity : *333*1*1*1#
  • Check last recharge detail :*333*1*2*1#
  • Check internet data & validity: *333*1*3*1#.
  • Check vas balance: *333*1*4*1#
  • Act calertune: *333*3*1*1#
  • Deact calertune: *333*3*1*2#
Act mis cal alert: *333*3*2*1#
  • Deact mis cal alert: *333*3*2*2#
for details just dial *333# from your Relinace GSM Prepaid.</p>
8 people like this
+1 nice find
Thanks for the useful codes. :)
+1
@nayasaroj
Edit this first post with the following=
Check 'Only for you offers' for that day only: Dial 151515 or SMS as OFU to 151515
Check last 24 hours call details: SMS as BILL to 151515
Thanks, +1
Is there anything like Voda's 121 self-service in RGSM?
In RGSM Prepaid, to activate some packs, by self,
Press *777# then CALL Button. You will get shortly
a popup message of PACKS MENU through which
you can activate.
thanks Saroj
tried to Check last recharge detail :*333*1*2*1# .But missed calls alert activated.15Rs deducted immediately
Be careful while using above codes.
For the above I use *367# for balance enquiring
*367*1# for promo balance
*367*2 for something I don't remember now and
*367*3# for data balance enquiring.All these run ussd codes and you can only see the message.No sms or like that.
Hope this helps.
1 person likes this
Helpful & informative,
What about message balance?
It's *367*4#
Dial *111*1*2# for checking validity of your Reliance GSM Rs.74 Local calling pack (Rate cutter)! This works for me in TN!
