@Akash
Blackberry 9670 Provisioning Problem
I flashed BB Style with PRL and data settings, but i am not able to dial *228. Do I have to provision manually everything?
Thanks,
Aakash
Dial *22801 and try, it should work. I don't have my 9670 with me right now with me else I would have confirmed you.
Sent from my SCH-I500 using Tapatalk
Nope, it is not working. I just realized i havent done NAM unlock. Is this the reason?
Transfer min manually if u know it, for more details mail me in genius@tclonline.in I shall get bak.
@Akash, its *22806, just tried on my BB9670, Welcome to Reliance.
Thank you Tarun. *22806 is working for me too.
*228 also got sub menu system like Reliance's Call Center IVR? Some naughty implications coming to my mind if this system is implemented with regard to Reliance GSM services!!!!
Press *228-01 to shut down your phone automatically if you are tired of our services.
Press *228-02 to get random choice of VAS activated lifelong.
Press *228-03 to know whether you are under coverage area or not.
Press *228-04 to get a phone signal if you are confirmed as under coverage area in *228-03.
Press *228-05 to sustain phone signal for next one hour.
Press *228-06 to increase call audio level (Not through phone's speaker.. Will work only with good quality handsfree!!)
Press *228-07 to get increased GPRS speed. Should be only enough to get you connected, may be read 1-2 E-Mail. No browsing guaranteed.
Press *228-08 to get pending bill calls from an english speaking lady with good manners and only 4 times a month instead of the usual 10-12.
Press *228-09 to De-activate Reliance 3G caller tune for next one hour (Will work only if you have subscribed to your own caller tune by paying Rs 30 + Rs 10 monthly)
Press *228-10 If none of the above works, press this to port out to other operators. (You will get this message afterwards... This service is not available on your connection!!!)
The PPP config's AN tab is not accepting XXX@hrpd.xxx.co It reverts to orignal XXX@hcm.sprint.com. Also, in MIP table the ip behaviour dont stick to simple ip only.\
Also the first profile in MIP has NAI as mynumber@hcm.sprint.com. I cant get rid of this.
On writing through QPST, it sends me some error NV_READONLY_S. How do I fix this?
@Thats not possible only with QPST.
I also tried that without success.
I think you will need official CDMA WS v3.x for this.
How to get MIN for my number? OTAP is not working.. *22806 tells me device not activated. Please contact customer care.
Edited by @Akash
min you can check by putting your sim in nokia phone
