joshm
The Gargoyle ordains "joshm" in the Holy Order of Samsung Fascinate as the Chief Priest and Fascinator. May his tribe increase.
Hi Joshm, currently im on SC 3 0.3 and i would like to upgrade to the latest SC 3 0.5 using the patch. I have downloaded the patch but not sure if i have to odin it or do it via recovery. I would also like to know if i will lose all my data and will have to reinstall all the apps etc.
well,, i installled launcher EX.. n it slows d fone to dead,, i want simple super clean.. wat shat i do?
jus flash reflash super clean or shud i do all d 3 steps.. i.e. odining n all?
thanks
well i guess just either try uninstalling this
or just go to the recovery and wipe all three :)
1.. data
2.. cache
3.. dalvik cache
you ll as good as new
But all contacts , sms es , call logs , settings , applications will be wiped !!, so plz back em up upfront
well, if i do wipe n all 3 steps.. will evdo setting,network stay or i have to reprogram ? have u ever tried before ?
@ Shanusmarty : of course i have done this a million times lol
nothing will be affected. you ll go back to the stocky state of Superclean only losing your apps and contacts and smses and stuff.
Edited by joshm
@ Silver1 : the patch needs to be flashed via recovery !!!
its a zip package and zip packages are to be flashed via CWM always
haa haa , Thanks mate !!
lets see how many are ready to come to my tribe ;)
Edited by joshm
Ok.....i'll remember that. What about all my apps messages n contacts....will I have to reinstall them
this is getting better by the day will have to do it sooner than planned
dear joshm do i need the same version of odin as shown in the image by you or some nearest version will do it
jasmin
@ JPShah : you can use the 1.6 version as well.
@Silver1 : see the data and apps are wiped only when you use CWM recovery and wipe data thriugh it , if you are just going to flash the patch then nothing will be removed.
thanks! mate! :)
UPDATE : as i dont have any permissions to edit the OP here are the latest updates SuperClean3 0.5 *11.30.11 (full rom, not patch) Download: http://www.multiupload.com/P40GUMW9FN md5: 169f75389f1248f2d83f14763efc2001 size: 159.88 MB SuperClean3 0.5 *11.30.11 (patch 0.3 -> 0.5 includes 0.4 updates) Download: http://www.multiupload.com/Q7F3SV6OWG md5: fbed04ac35eeff0f5839bd565b8c3730 size: 22.52 MB SuperClean3 0.4 *11.29.11 (full rom, not patch) Download: http://www.multiupload.com/HG6QFZOXIX md5: f7be7efbd35b6a4538dc7d70c58c7415 size: 160.87 MB
hey mate i dont remember that i m on which super clean version,, so can i update with full rom ?i.e.3 0.5 (full rom, not patch)
thanks
thanks
yes of course you can :)
although there is no need to wipe anything , but in my view its always great to wipe all three ( provided you have ur contacts , sms es and apps backed up )
:previous:
how to wipe the patches?
:previous:
LOL where did i say to wipe patches
wipe data , cache , dalvik if you want
otherwise just flash the new patch or ROM over the existing SC version.
Okay a few more patches for Superclean Rom
Patches:
(flashable in cwr unless noted otherwise)
visual voicemail patch: http://www.multiupload.com/QF5ZZ0MSF0 *12.8.11
md5: ACF9F4AFBA169FCD46520B03031DA0EE
extra flip fonts: http://www.multiupload.com/GZJSHGNR3L *12.2.11
md5: 92be84c9ec688ecca03fc8b916f0beb4
(change font in settings - > display -> set fonts) screenshot in post #2
dialer w/ gv remap of vm button: http://www.multiupload.com/XH2EWNEJEY *12.2.11
md5: f0b1f912e349a8aa4a688e37fdf18c35
(voicemail button launches google voice instead of verizon visual voicemail)
Google Car Dock: http://www.multiupload.com/LNN0YWWY0G *12.7.11
md5: D1C7965A9CCF52A245D761ACFC66716D
(better than touchwiz dock imo and configurable)
Transparent Status Bar Pulldown: http://www.multiupload.com/IKG37ERTCN *12.7.11
md5: 713DB3C5CF5871C1C360E58B0BB34CB9
aosp lockscreen: http://www.multiupload.com/3SIKRV2MW6
md5: 1831d87dfc1c5538f042b7f4d3553ae7
***first boot will take a few minutes as the android.policy.jar is being overwritten***
tsm launcher2: http://www.multiupload.com/AQ7XB43UHP
md5: 24b34abd64fa11f9c7ffae4b4e1c3233
(screenshots at bottom of page here...ignore the rom mods as its shown on resurrection)
ei20 car cradle: http://www.multiupload.com/Q9AMD8G79I *11.22.11
md5: 0d35a2c8412789e9db25d9b862af5dcf
(fixes issue with navigation, maps, and voice search giving "no activity installed", but does *not* include music quick launch!)
stock touchwiz launcher from eh03: http://www.multiupload.com/B6NWXGK8UG
md5: 8383b85a4667ad6bbd291c14b5da0826
samsung touchwiz widgets: http://www.multiupload.com/TYTQQUWG52
md5: c058b419e2433d55c14166a1ca42d758
(will only work with stock launcher)
eh03 verizon apps: http://www.multiupload.com/KF8AMPCABF
md5: 990eca3b8d3e379d2b2fe9ce8746a2f7
alternate touchwiz gallery: http://www.multiupload.com/XEG5X4J3ZX
md5: fa350f312a72c0483a23b489cdd3f867
bing package: http://www.multiupload.com/EXWG6652WR
md5: f4da71aa9cb56152ae8507903e750430
(bing search and bing-ed browser)
bloat/ripoff games and apps: http://www.multiupload.com/WY6V7O3GV0
md5: 9ade9ded0871ff538b0760a93fd24639
(blockbuster, city id, madden, nfs, quickoffice, media hub)
livewallpapers: http://www.multiupload.com/4F7KCDQ7WB
md5: f6af93c42a9e0f257ac053fff4519106
accurate battery mod for 1% increments http://www.multiupload.com/3GTICG6AD2
md5: 8e8814e7cdc3328cd8ca21d9f84a235f
stock screenshot app: http://www.multiupload.com/KF1JMLJFP6
md5: c51bcf423bf9a813ac78baa9fad63548
  • Like 7
Guys.. josh has really put a great effort on this post & as I can see many of you have been using this method/post to update but only 2 reputation points!!!
Come on... You just need to press the green button in lower right corner of 1st post as suggested by Rajanbhai...
Thanks a lot mate !!
means a lot :)
god bless
@ ALL fascinate users : if you have any doubts or need help in updation leave a reply with details and i ll try my best within my limits
regards
Moderator this is my conversation with joshm to help me out to upgrade my fascinate to gingerbread and now he wants everyone one to see the conversation so people should benefit with it.
andydesai:-hi their i been going through your post to upgrade my fascinate from 2.2 foryo to gingerbread through the procedure you have mentioned but the link for the download file i am not able to download bcos it says after some time tht the source file could not be downloaded bcos it ould not be read or something like that can you tell me any other link for the same.'
Please help
Joshm:- if you are having a slow connection, that may be prompting it
as far as i checked all links are fine , try using some different host
try this link
http://www.filesonic...3_GB_CM.tar.md5
should work
btw i am uploading the file to rapidshare too as we speak will give you the link once done
install this file with only and dont do anything else for now
andydesai:-thanks for your fast reply, the file on the filesonic i cannot download bcos i am a free member, please give me the link of rapidshare once your done posting..
joshm:-here you go
https://www.rapidsha...3_GB_CM.tar.md5
andydesai:-thanks again i am dowloading it has i am typing this to you. Also will let u know if the download fails. Do you have any idea how samsung epic touch handset is bcos i am planning to shift to that.
joshm:-i have an epic as well as fascinate , and i can safely say fascinate is better in all regards
first up its half the weight
sliders are always prone to get messed
epic has a perennial issue of not getting recognised by windows
its got a bug of getting disconnected while on evdo, signals vary a lot in it
i personally use fascinate only and my friend uses epic .
andydesai:-Thanks mate got the file downloaded at last will upgrade to gingerbread and wilk let u know, by the way I am upgrading to samsung galaxy s2 epic touch 4g and not epic which you thought thats why you are talking about slide out keypad right??
joshm:-O lol , yupp i didnt pay full attention ;)
yupp Epic Touch will be great , its just more powerful and better looking fascinate ;)
go for it
see ya
andydesai:-hi freind now i have problemdownloading the RED RECOVERY 2.5.1.x when ever i click the link it says the site is blocked.and thanks mate now i am on gingerbread and now i would liketo flash superclean 3.0.4.
joshm:-plz add your queries in the main thread so that all others can also benefit from the solutions.
reegards
hi joshm now i have problemdownloading the RED RECOVERY 2.5.1.x when ever i click the link it says the site is blocked.
see:
@ andydesai : here is the rapidshare link to the RED recovery, looks like your Service provider has blocked Mediafire.
https://www.rapidsha...LL-3-30-FIX.tar
dear i already uploaded the file 2 days back for you and i asked you to put new queries here in the thread ;)you can omit the alreday done conversations
:previous: Rapidshare is blocked on Reliance Communications (Broadband/NetConnect) as well.
@joshm the file i downloaded for the red recovery thru rapidshare, once i unzip it the file extension is showing as recovery.bin and which i am not able to load in odin.
hmm..
wth ? i have goty it uploaded to multiupload now
download from any unblocked host ;)
http://www.multiupload.com/9CZSLTTYE6
If you people want me to upload other files as well to multiupload plz temme , will do as soon as i can.
@ ARUN , mate could you allow me to edit the first post of the topic, coz it will become cumbersome to post updates spreading on so many pages.
regards
O man , its a tar file , you dont have to extract it , it has to be used as is in ODIN man !!!
