sadanand.sapkal
How To Enhance EVDO Signals?
Dear All,
Recently I bought Samsung Google Nexus S 4G CDMA. After activation of EVDO, overall I am getting good net speed with EVDO signals. But in my residing area the EVDO signals are very weak and most of the time I am getting 1x Signals only. Its really disappointing when I use net with 1x signals.
I have complained this to rcom also but there was no improvement in evdo signals except the promises from customer care.
I request all the experienced members here to suggest me any remedy to boost the EVDO Signals within my residence as I am not expecting much from reliance customer service regarding this issue.
I am residing in Ambernath, Dist-Thane, Maharashtra.
Awaiting some good remedies/solution to boost the evdo signals.
Regards,
Sadaband Sapkal
Try changing Phone's Radio firmware, changing software. I don't think there is any other way else.
use this radio
D720SPRLC1 from here:
http://download.peteralfonso.com/crespo4g
Install Rom manager from market first if you don't know how to flash ROM/Radios.
You can also use this ROM:
crespo4g_2012-06-09 from this page:
http://download.peteralfonso.com/crespo4g/rom (its the last one on the page). Its quite good for NS4G.
Anyone has any fix for the poor WiFi reception on Nexus ? Mine only works when in the same room as the router ! While iphone/laptop/BB all work in other rooms and even outside the house.
Thanks KapilAgrawal & ami1 for suggestions, but I am a laymen in this field, so I don't think I will try these software things in my phone.
I believe my seller has done the best while programming my number & net settings for my phone.
I am thinking of some external remedies which can enhance my evdo signals.
Pls share if anybody is having some external solution for increasing the reception if evdo signals.
Sent from my Nexus S 4G using Tapatalk 2
I believe, radio and firmware updates are your only and best bets.
Everyone is a Noob when they do something for the first time, just go to appropriate xda forums an learn about updating and all in there. Will require just one hour for 3 days to get a simple idea an then all the rimweb community is there to help u.
I dont have 0 clue about ur phone othereise i would have guided u.
All the best
From my utterly Fascinating I500 Fascinate :-)
Thanks jishm,
Whatever you as well as KapilAgrawal & ami1 said is completely unknown things for me, but I think I should start exploring these software aspects now as using imported cdma phone will always require such kind of knowledge in future also.
Will request support regarding this if required.
Thanks all for guidance.
Hello Joshm
I have samsung EPIC 4G TOUCH & have same problem. I am hardly able to find EVDO signals in my office. I have complaint for this in reliance, but as usual "we can't help on this"
Pls suggest me any solution to get SIGNALS in my office. Except my office i m getting good signal strength. signal problem is just around my office.
Pls help.....
I need to know..what signal booster does..and is it reliable in india?
check this page : http://cellsignalboosters.in/CDMA-800MHz-kit.html
this is a signal repeater or booster..its boost's signals inside the house or office...i need to know...anybody have any ideas abt how this thing work!?
Repeater works, they have amplifiers. I have one installed in my office by reliance.
Hello sadanand,
I too resides on ambernath. I am using evdo from last 1 and half year in ambernath. I havent faced any major issue.
But from one month, there is bit an evdo problem in ambernath.
Its regularly switching to 1x. Right now also its on 1x.
Before on day time i was easily getting 1mbps and in night more then 2mbps.
Just wait for few days. It will get resolved i have no idea where yoh live. Some places in amb hav strong coverage. Stn side, mohan jyot, shaka. Easy get 1mb or more anytime.
Sent from my EVO using Tapatalk 2
Thanks Sunil for your concern.
I will pm you my location.
i have similar issue with a htc droid eris.
would any one possibly know what radio can i flash to improve evdo signals.
Yesterday i call to RIM CC & asked them for repeater but they have no idea.
In your case, have they charged or not for repeater? If yes then how much?
