_Kailash_
HTC Thunderbolt Problem
Hi Friends, I was 2.2.1 and everything was working all right, then I roooted it thru revolutionary , but then I thought There was no use of rooting , So I Unrooted, now the problem I used thunderbolt tool to Unroot and it updated my software to 2.3.4 which was good but the only problem i face is that I cannot make calls , SMS works, incoming works, tried all wipes reflashing re rooting , unrooting , bootload flash , but nothing seems to make it call,, Please help if you Can, Thanks Guys
did you check your handset programming ?
Yes the programming is perfect,
I even had the AKey Entered Again, but still no help...
Its doesnt ring and If I leave it for any no of hours its will be the same un till i end the dialer storage app...
Edited by _Kailash_
What all did you wipe ??
System, emmc ?
FULL AND Cache but that was before upgrading to Ginger_BreadRock_V3.3B
FULL as in ?? Elaborate.
WIPE DATA/FACTORY RESET
Wipe Cache partition...
As per my past experience with Thunderbolt on GB, you have no options but to dowgrade back to the Froyo.
My problem resolved with downgrade to full froyo, though you can try also by downgrading the Radio.
Exactly Even I feel the same needs to be done, but I can't find the official Stock froyo anywhere , all are modded rooted and stuff, if you have please post the link here or Gtalk: Kailash.m
And PM me Please..... if not Official At-least the working one please
I Will have to find, there was some thread on XDA with all the links.
Though I have the Stock Froyo Firmware saved on my PC, but uploading will take time, its a 400 MB File.
I will post the links as soon as I find on XDA or my file uploads.
All in one Guide to Un-Root and Downgrade
This should solve your purpose. For more stock firmwares visit:
Stock Firmwares
It worked Thank you so much.. yippie i changed the rom to the 651.6 and it worked
Thanks +1 for you :) M Back on 2.2.1 and Happy LOLZ :)
Even i also faced same problem last week only but solved it by exploring on google!
Yes the above information is superb!
Did you solve it by downgrading form 2.3.4 to 2.2.1????
Let me m curious as I really Loved the 2.3.4 Interface and speed of thunderbolt...
i have problem in htc thunderbolt, i tranfered my mdn to the handset and entered the MIN no by entering to ##program#, but still i am not getting incoming call or outgoing calls, i retrived 10 digit min no from sim and entered first seven digit in min 1 and last three digit in min 2. i am not able to connect handset to pc in diag mode also so that i can check all parameters in cw or dfs. my handset is rooted and its on ics 4.0.4, rimweb gurus pl help
@Sandeep try to enter min using CDMA Workshop
Sent from my XT907
@ VIJAYMALHOTRA, I am not not able to connect handset in diag mode on cdmaworkshop or dfs. mine hander is rooted to HTC sence 3.6
If u r on custom rom like CM. This will help
http://forum.xda-developers.com/showthread.php?t=2250865
Sent by Moto G on Reliance CDMA
Thanks hiteshji for ur valuable input, but after entering min no, and mdn from dfs, the outgoing call it pops, the call is lost, and incoming call it says the mdn is not reachable or cannot be contacted. I have written akey to phone also.
Hope your min is correct and written on correct place
Sandeep just read this thread, you only needed to do ##PROGRAM and enter the SPC then enter the MIN per Parin bhai's E-Mail
There was no need for DFS or CW or writing A-Key all that was already done
I now doubt that the programming has been messed up in doing all this
