HetalDP
Reliance EVDO Rev B. Multicarrier - Reliance Pro 3
@huaweitrick02
First tell how have you managed to access MTS rev B on reliance ruim?
boss it takes one month for testing and complete working of rev b on my device.
i m using latest version b prl no 5 on my device .
and getting it worked here.
sent by :- huaweitrick02
How do you perform PRL ugrade on RUIM? Cmon man, share it! We all can benefit.
Which company dongle you r using? You are pay 6250 to reliance for 12 month?
As per my Enquiry in mobile store at Borivali in Mumbai, they are giving me 6 month period for unlimited plan only.
I wants to buy pro3 dougle. So I getting checking my net speed in my mobile. Currently I am using Micromax AE90.
There are two default APN setting in it.
First one is reliance modem who's setting is change by reliance shop person as username and password as my mobile no...... I am getting 0.5 to 0.3/ 0.2 to 0.45 downloading uploading speed in it.
Second one is reliance wap. In this my username is 'SpiceD88@wap.relianceinfo.com'. Password unknow (any one can guide me for same for password). I am getting 0.98to 0.78/ 0.47to 0.45 downloading uploading speed.
Above results are getting me at same position in Mumbai suburb area.
Sent from my Micromax AE90 using Tapatalk
For 2nd profile how many dots are there for password ? Please advise, may b I can figure out password.
Is mts upgrading its server to 9.8 mbps to 1r.4 mbsp
the magic happend today i dont know
i m today getting generally batter speed ; ☺ normally
i got 3 to 4 mbps speed in day time.
but when i found speed is going much batter i m getting more than 1 mbps in idm , downloading speed.
after going on speed test.
i found
3 to 4 time test done
getting 8 to 11 mbps speed
now question arise
in delhi mts only provide 9.8 mbps than how i m getting more than this.
i think mts is upgrading its server and testing is going on....
i found
now question arise
arent you connected to WiFI in both of your screenshots?
yes , wifi conected with
reliance rev b
Hi all,
After using almost 1 year RCDMA in Bangalore, I am writing about rev.b
1. No fup limit for data. I have used 4999 plan, 949 plan and 71 plan(previous 41). I have downloaded around 800 gb in 4999 plan, 130 gb in 949 and 20 gb in 71 plan without any fup.
2. There is no any special plan for 1x, rev.A or rev.B..whatever amount you are recharging, you will get speed according to your area covered by 1x, rev.A and rev. B..suppose you have recharged with 94 (1gb), and you are in rev b area you will get rev b speed otherwise rev.A or 1x.
3. No special sim required for rev.b, whatever sim your handset supports for data is good enough for rev.b either it is rge or rec series..
Now rev.b Handsets:-
1. Now a days almost all foreign handset support rev.b..Just make it rev.b through dfs tool thats it..it start working if your area is covered under rev.b
Anyone using revb in Borivali West or Goregaon East?
Sent from HTC M8 using Tapatalk.
Kandivali West / andheri East
Sent from my A0001 using Tapatalk
yes u can use that sim i delhi
but rember sim should be alredy activated in home circle.
use paytm; mobikwik to recharge it.
it will work
evdo also work after sending HSD msg.
thanks
it will work
Bit off topic, I am using HTC Desire 510 with MTS OMH SIM, and getting only Evdo A. How to get mts rev b on my phone?
if you have native reliance Rev.B towers, Try this..
if you have MTS towers for for reliance Rev.B need not try.
Since you have MTS sim make try and let it be know to every body if it works.
EHPRD to REV.B and Change SCP force AT config to - REV.B
Edited by Guru Gopal
M from Gujarat
M using unlocked huawei ec306 dongle with reliance omh sim but m getting only rev a. How do i get rev b speed?
Sent from my HM 1SW using Tapatalk
put the sim in the cdma smart phone mobile and then send the message HSD to 55444 and after receiving the confirmation or after half and hour
put the sim back in the dongle
if i use maharashtra rcdma sim in delhi can i use rs149 evdo pack and will i be able to activate the pack using online recharge portals like paytm, mobikwik etc
I am using Delhi CDMA SIM in Kolkata for last 2 years. Recharging with Paytm and official Mmyservicesada. no issues for both.
M from Gujarat
Rev.B on SIM is possible only if Rev.B is offered by reliance. for interconnect through MTS, its not possible.
Edited by commonman
M from Gujarat
I have had the same experience in Pune. The smartfren dashboard does not say which type of tower it has connected (Rev A or B ). It might be possible to flash another dashboard, but I have not ventured down that path.
As I see Reliance coverage is pathetic and the speeds are close to 200 kbps outside my house. Yes, cheap 3G, but pretty much useless for me. I have tested this at my home in Mumbai as well as Pune.
Edited by vakharia
huaweitrick02
Can u please tell how to use RCDMA Rev. B in delhi and Ncr. kindly share PRL settings. ive ordered huawei EC 306 and already using REV. A in EV 156
Hi all,
Hi sameer.. someone said 949 plan has FUP limit on 5Gb.. ie., since last month they had put FUP on this plan.. is it true?
can someone kindly confirm pls?
anyone knows if HTC 828 support Rev. B?
After merging mts & reliance, should we get Rev b on non rev b area?
Sorry to ask OFF TOPIC
I just found that previous username and password (10 digit MDN & net) is not working with my Reliance CDMA RUIM when tried via AC2766 modem.
Though data works on my HTC 510 smartphone!!
Any idea ?
