pasumark
Help: Samsung Galaxy Nexus S (CDMA) Not Switching On
2 days back when I switched on my Nexus S, it got stuck up in the starting screen 'Google'. So I removed the battery and again switched it on. It started to work. Yesterday in the afternoon, suddenly it froze and again I had to remove the battery and and then switch it on again. Afterwards it was working fine.
But today morning (After switching off in the night and charging it), when I switch on, it moves from 'Google' screen to the colourful display and gets struck up there. The colour keeps on splashing and it gets stuck up there. I remove the battery and again try to restart. The same problem.
My phone is in latest Android 4.0.4
What to do?
!. If the phone cannot be revived immediately, what are my options to use my number? What should I tell in the webworld to change this no. to a SIM? And in future, if the Nexus S is corrected, how can I switch back no. to it?
2. What decent SIM based phones are available IMMEDIATELY, both in our forum and in market?
Please help guys
Edited by pasumark
If you are on stock firmware, simply factory reset from android recovery...
It works most of the time..
Sent from Motorola Photon 4G via Reliance
Thanks for your immediate reply
I am in stock firmware only. I have not done anything like rooting etc.
Can you guide me on how to Factory reset?
Thank you very much.
I did the Factory reset and it has started to work
Nexus S runs best on GingerBread.. 2.3...
waiting for jelly bean.. But excellent on 2.3.. :)
Sadikk,
Should I come back to GingerBread 2.3? If yes how?
Or should I continue till Jelly Bean
Today afternoon again my Nexus S froze. First I tried to remove battery and restart again. It didnot work. Then I tried to do Factory reset. After Factory reset it just keeps on re-booting - Google screen comes colour flashes and again it goes back to Google screen.
What can be done?
try to use ODIN & Flash the firmware
Thanks Parin.
For the past 2 hours, I googled a lot about Flashing the firmware. But to be frank, I am unable to proceed on my own. I feel it is not my territory.
Can anyone do this for me online(connected through Team viewer) or even if the device needs to be sent it can be done?
Pls guide me
Thanks Parin.
Will surely try and give you feedback
Dear Parin,
I flashed the firmware with ODIN as instructed in the website link provided by you. The flash was fine, the ODIN said PASS and my phone re-started. But no change - still the same problem. keeps on re-booting - Google screen comes colour flashes and again it goes back to Google screen.
Any other option?
Even Shadikk was online today and tried to Flash it through Team viewer. But no improvement and could not figure out. He has asked me to courier the phone.
Hope it gets solved.
Meanwhile Thanks very much for Parin, Shadikk and Kalpesh.
is your phone sim based or non sim based ?
based on your earlier posts i guess its a sim based.
Switch off your phone, remove sim. get a hair dryer,
set it to warm and blow WARM air from behind the phone.
make sure you DO NOT hold the dryer very close to the
phone. keep it at least 1ft away from the phone. do that
for 5 mins and then insert sim and battery, reboot.
do a factory reset again and give it a few days to see if it restarts again.
the above information is to try at your own risk. found this after searching on XDA website.
it has solved the exact same problem you have with your phone.
please make sure that you are not in a air-conditioned place.
Edited by Vinod Nayak
It is non sim phone
Ok why don't you give it a shot.
Sent from my SPH-L710 using Tapatalk 2
Toady my nexus s 4g went dead for no reason, I was trying to make a call, screen got disstorted and stopped responding. S free few seconds I had to remove battery as nothing was happening, now it is not turning on at all. No bootloader or download mode nor os is coming up.
Any help about possible ways to make it on?
Simple unbrick tool is available for GnexS 4G in nexus s 4g q&a on xda.
Sent from my EVO 3D on Reliance using Tapatalk
Thanks Dr. I checked the thread. Need Ubuntu download so preparing for applying mod. Will keep you posted.
Mmmm... Have you checked whether the battery has not died?
Happened with me for one of the phone.
I turned the world upside down and tried every damn solution only to find out later that upon replacing the battery, everything worked instantly.
Try this - remove battery, insert charger, insert battery, try switching on phone.
This problem is epidemic in Nexus S, as I understand from xda and other forums. Mainly when phone is on ICS or JB.
I am going to buy soldering iron for mobile phone (small and pointed) and going to try to revive phone tomorrow.
http://forum.xda-developers.com/search.php?searchid=85817483&pp=25&page=2
Update : Attempt failed :doh:
@ Rajan, yes battery checked and its perfect.
Reason, mod explained on XDA is for GSM phone. CDMA board is different.
Bought Rs 250 soldering iron and opened phone with hope that I will be able to do as mentioned. But when opened phone realized that photo is atleast 15 - 20 times the actual board. I could not see practically any resistor properly with 4X magnifier, so had to use 20X industrial microscope to see circuit
Circuit in CDMA board is entirely different than that of GSM so could not do any thing, just reassembled phone and posting this. :smoke:
Edited by kshah
Jtag resurrection
^Is there any JTAG repair person in India, if aware of any then please share the details, will help many.
Please excuse typos and brevity, sent while mobile.
