Genius 817 Report post Posted September 19, 2012 (edited) Palm Treo 755p was the dirst mobile i put in diag mode after carefully following D K JI's guide Since then the most difficult part i come across is remembering how to get it in diag mode as i forget codes and methods all time, so i am gonna list it out for me as a ready guide. Before you begin: Get latest / old / Modified drivers for your device Get respective cable and off you go Palm device Sprint Treo 755P / Sprint Treo 800w ##3424# for ##DIAG# select the port Palm Pre / Pixi & Plus Bypass Activation Download Code generation from Hitesh post pass key gen get SN from device back or Info Navigate to phone dialer. Type ##USBPASS#, enter the 5 digit code recieved from the pass key gen. Navigate to 1 and change the port to diagnostic port. Plug in phone. You have access to diagnostic port. Don't forget to go back to the usbpass and take diagnostic mode off when complete it gives option to charge or mtp mode. This key will also work to enter in palm code to edit data settings such as mmscurl in ##3282#. Samsung Mobiles Fascinate Manual Program From the phone dialer screen, press * * 7 7 2 Enter 000000 Scroll down till you see SVC MODE NAM 1 CDMA Directory number Tap to enter MDN then hit enter Enter MIN number then hit enter Now just keep hitting enter until the phone reboots Diag mode Go to Menu, Settings, Applications, Development and check "USB Debugging" Bring up the dial pad on the phone and enter **87284 (**USBUI) you should have 2 different options on the screen select MODEM for both options phone is now on diag mode 16digit Pass: 2010031619780721 EPIC Manual Program Enter ##000000# Select edit mode and enter 000000 Type in your 10 digit MDN number and hit enter Type in your 10 digit MIN number Now just keep hitting enter until the phone exits the programming menu and reboots DIag Mode In 2.1 Just enable USB debugging (Go to Menu, Settings, Applications, Development and check "USB Debugging") go to Wireless Controls and Enable Dial up Networking Epic 2.2 or higher Enable "USB Debugging" Bring up the dial pad and enter ##8778# You should have 2 different options on the screen Select MODEM for both options Reboot phone with usb plugged in 16 digit Pass: 01F2030F5F678FF9 Continum Manual Program Same as Fasfinate Diagmode Bring up the dial pad on the phone and enter **87284 (**USBUI) you should have 2 different options on the screen select MODEM for both options phone is now on diag mode 16 Digit Password 2010031619810219 EPIC 4G Manual Program Same as EPIC DIAG mode enable "USB Debugging" enter ##8778# You should have 3 different options on the screen Select the "ALL" option NExus S 4G Manual Program Enter *#*#000000#*#* Select edit mode and enter 000000 10 digit MDN number and hit enter 10 digit MIN number Now just keep hitting enter until the phone exits the programming menu and reboots Diag Mode (thanks Tarun Kabra Ji) ENABLE "USB Debugging" dial enter *#*#8778#*#* 2 different options on the screen Select MODEM for both option Juke and Smooth Manual Program Go to Menu, Settings, * Enter 000000 for SPC Code or what u have Select Network Settings Choose Phone Number and enter (MDN), press OK Choose NMSID to enter MIN (00 followed by the MIN) Press OK Press Exit when done Phone will restart and Programming is complete. Diag Mode Menu - Setting & tools - plress # - dial MSL - go to MTP settings - Select MSM for DIag and MTP for music transfer ----------------MORE to CUM---------------------- To bypass activation screen, press emergency call button, then at the dialer, press* # 8 3 7 8 6 6 3 3, press the Home key. Samsung S3 / S2 Some Samsung phone the diag mode is in hidden Menu get it by (thanks to Parin) *#22745927 then enable hidden menu Then dial *#7284# or ##3424# Select QXDM USB Settings & Select Last option where there id DM (diagnostic mode) HTC Mobile ##3424# (tarun Ji) Motorola Mobile BP Tools is supported by (thanks Kapil Ji) Motorola Droid Bionic Motorola Droid 3 Motorola Droid 4 Motorola Droid Razr Motorola Droid Razr Max Some new bootloader on Droid X2 & Photon also support this MOre to Come --- if I have missed something please guide me or post below as your contribution Edited September 26, 2012 by Genius 22 Share this post Link to post Share on other sites
tarun_kabra 204 Report post Posted September 19, 2012 Please add the easiest one HTC - ##3424# Also for Nexus S4G - *#*#8778#*#* 1 Share this post Link to post Share on other sites
aalok 442 Report post Posted September 19, 2012 chand nazar aaya bhai chand nazar aaya.... tarun bhai, welcome back... 1 Share this post Link to post Share on other sites
rahujas 16 Report post Posted September 19, 2012 Mods please pin this topic. Share this post Link to post Share on other sites
KapilAgrawal 340 Report post Posted September 19, 2012 Add Motorola as per your earlier post. BP tools Share this post Link to post Share on other sites
mac_lion 13 Report post Posted September 19, 2012 thanks, very useful Share this post Link to post Share on other sites
deepv84 2 Report post Posted September 21, 2012 thanks! sir ji Share this post Link to post Share on other sites
rcdoma 1 Report post Posted September 22, 2012 Very useful post, thanks! Share this post Link to post Share on other sites
dr.faramroze 703 Report post Posted September 22, 2012 LG optimus s,m,v,c and marquee will be added. Sent from my Sensation XL using Tapatalk Share this post Link to post Share on other sites
Genius 817 Report post Posted September 22, 2012 LG optimus s,m,v,c and marquee will be added. Sent from my Sensation XL using Tapatalk Adding it soon its ready Also changing structure and getting codes also in it Share this post Link to post Share on other sites
aalok 442 Report post Posted September 22, 2012 doc saab working so late.. Share this post Link to post Share on other sites
a1cellsolution 84 Report post Posted September 23, 2012 @Genius nice collection once i got a samsung fascinate it will connect with the cdma workshop but not read the set this solution worked for me please add this also will help many other members this also worked for samsung galaxy tab for a friend 1: dial **33284 2: Enter 000000 for spc 3: Port map and make sure you have HFK, DIAG set and NOT HFK, NULL. Share this post Link to post Share on other sites
supernova 47 Report post Posted September 24, 2012 Codes for iPhone for changing my number being shown in phone. Of code where min is put Share this post Link to post Share on other sites
Genius 817 Report post Posted September 26, 2012 Codes for iPhone for changing my number being shown in phone. Of code where min is put this only aomes when you flach your carriar bundle of cricket - not other wise its ##626 - dial enter SPC enter MDN enter MIN 1 Share this post Link to post Share on other sites
ddas8888 2 Report post Posted January 30, 2013 Please add for lg spectrum vs920. Could not able to program this beast. Share this post Link to post Share on other sites
Genius 817 Report post Posted January 30, 2013 Please add for lg spectrum vs920. Could not able to program this beast. Enable USB debugging from settings and that's it it will be found in diag mode in PC, most of LG phone work this way you can try ##000000# or ##SPC# use right drivers 1 Share this post Link to post Share on other sites
ddas8888 2 Report post Posted January 30, 2013 USB DEBUGGING does not help. Only phone can be read with cdma workshop/qpst in debugging mode but not writable. What to do? I am a newbie. Pls Hlp.. Thanks. I post this to another forum and someone has advised me to enable usb init from kernel and dial ##PROGRAM920. But how can i do this? I am new to android also. Share this post Link to post Share on other sites
aalok 442 Report post Posted January 30, 2013 ^ ##PROGRAM920 = ##7764726920 2 Share this post Link to post Share on other sites
shanusmarty 29 Report post Posted January 30, 2013 really nice and helpful! Share this post Link to post Share on other sites
joshm 817 Report post Posted May 16, 2013 sincere thankies had forgotten a few things , but i knew I can get the info from here regards Share this post Link to post Share on other sites
dr.faramroze 703 Report post Posted May 16, 2013 For de-programming Samsung Axiom US Cellular, go back to stock 4.0.4 and do ##72786# and continue with ##data# for choosing the appropriate band for RUIM based internet. Anycut and hash codes don't work on stock 4.1.2. It would be still better if someone could put a flash tutorial for the Sam Axiom. Sent from my GT-P3100 using Tapatalk 2 3 Share this post Link to post Share on other sites
snorlax 319 Report post Posted May 16, 2013 I was on jb on axiom. Flashed stock ics two three times via odin. The phone never booted past Samsung logo. Had to flash jb again to make the mobile live and running. So I would be really interested if someone could throw some light as to how to go back to ics from jb on the axiom. Share this post Link to post Share on other sites
rawda 8 Report post Posted May 16, 2013 For de-programming Samsung Axiom US Cellular, go back to stock 4.0.4 and do ##72786# and continue with ##data# for choosing the appropriate band for RUIM based internet. Anycut and hash codes don't work on stock 4.1.2. It would be still better if someone could put a flash tutorial for the Sam Axiom. Sent from my GT-P3100 using Tapatalk 2 Hi How to go back to 4.0.4 and Reliance Data will work via RUIM? Share this post Link to post Share on other sites
dr.faramroze 703 Report post Posted May 16, 2013 (edited) Samsung Axiom R830 US Cellular onlyStock update 4.1.2http://wccftech.com/install-vxbmb2-android-412-jelly-bean-usa-galaxy-axiom-schr830/http://www.mediafire.com/?7v7zor9d379emeghttp://www.hotfile.com/dl/201613344/21942be/R830VXBMB2_R830USCBMB2_USC.zip.htmlPlease use exact odin version with the stock 4.1.2 image above.Stock image 4.0.4This is an Odin Flashable file meant for unbricking/unrooting the deviceIt has a pit file included*check* Freset Time*check* Auto-RebootPit = PIT slotTar = PDADownload:- http://teamuscellular.com/Forum/files/file/138-stock-files/ _____________________________________________________________________________________________________________________Do not attempt to change the following settings if 1x/evdo is already functional. Your radio will change signal band and/or go offline. Settings applicable to US Cellular Axiom, US cellular S3 RUIM based.Enter *#22745927 on the dial padClick on the Hidden Menu Option to Enable the hidden menu (It will reset itself to disabled on every restart)Enter *#197328640# on the dial padAt the Service Menu, follow the options below2-CDMA1-Common9-NextPage9-NextPage8-PREF MODE SET1-CDMA_HDR_LTE_OnlyMenu ButtonBackReboot Phone2-CDMA4-Control9-CDMA BAND SELECT4-AutomaticWe can on/off mobile data toggle on Samsung US cellular S3 and Samsung Stellar but if we turn off working data in settings in Axiom, it will require a factory reset and/or downgrade to 4.0.4, clear NAM settings by ##72786# and again update 4.1.2 for data to work. So data should not be turned off on an Axiom, working 24x7 permanently. Samsung Stellar i200 (Date: 05/06/2013) These tricks will work on stock 4.0.4 ICS stock ROM only. Enter *#22745927 on the dial padClick on the Hidden Menu Option to Enable the hidden menu (It will reset itself to disabled on every restart)Enter *#197328640# on the dial padAt the Service Menu, follow the options below2-CDMA1-Common9-NextPage9-NextPage8-PREF MODE SET1-CDMA_OnlyMenu ButtonBackReboot Phone2-CDMA4-Control9-CDMA BAND SELECT4-Automatic Reboot again Dial *#22745927 and enable Hidden Menu Dial ##3282# edit->others->1x HDR selection->make it Hybrid Mode back Goto Korea Mode Set (Mostly this mode selection will be off default) Select India Mode Full and final reboot Programming Samsung Stellar on Non-Verizon CDMA networks worldwide. This is experimental, use your own discretion to explore further. To put the Sam Stellar in Diag mode On the phone please dial *#22745927 to enable the hidden menus then dial *#7284# or **87284 (USBUI) select ""Qualcomm usb settings"" and select DM+MODEM+ADB then select ok Samsung Diagnostic port will be detected. Can continue with any tools available. Edited June 5, 2013 by dr.faramroze 8 Share this post Link to post Share on other sites
prihir 53 Report post Posted May 17, 2013 Done !!! Thank you Dr. sab 2 Share this post Link to post Share on other sites
