kundalus
Code Dialer issue (+) with Verizon handsets
Hi! Guys,
I have used many VZW phones and most of them were used on GSM network. I have one issue, how to solve the issue of dialling a local/indian number. Everytime u dial a number that doesnt have country code it takes +1 as default. I need to understand how to solve this issue.
Can someone help???
Check in three dialer option. Turn it of from there.
Dipesh bhai,
Disable Plus code dialing in call settings ....
The most US phones, by default adds '+1' when any number starts with +. Earlier, in some phones there was option where you can decide what to replace '+' so you can choose replacing + sign with 00 and it worked. However this could not work while sending SMS. I had similar issue with my Epic 4G. The only option is to change the numbers from + sign to desire prefix or use any of the above mentioned apps.
Here is site that changes the prefix as per your desire. I had changed it from +91 to 0 from this site. Click here
I also have Macro that works on Outlook contact to change the prefix from 0 to +91. I am putting the code below. You can copy paste in the Macro in outlook.
I AM NOT RESPONSIBLE IF IT MESSES WITH YOUR CONTACTS. USE IT AT YOUR OWN RISK
Sub FixPhoneFormat()
Dim oFolder As MAPIFolder
 Set oFolder = Application.ActiveExplorer.CurrentFolder
' Confirm it's a contacts folder by looking at the default form name
' to see if it begins with "ipm.contact".
' This allows it to work on folders with custom forms
 If Left(UCase(oFolder.DefaultMessageClass), 11) <> "IPM.CONTACT" Then
 MsgBox "You need to select a Contacts folder", vbExclamation
 Exit Sub
 End If
Dim nCounter As Integer
 nCounter = 0
Dim oItem
 For Each oItem In oFolder.Items
 Dim oContact As ContactItem
' If the current item is a not a Contact Group process the phone numbers
' If it's a DL, the code moves on to the next item
 If TypeName(oItem) <> "DistListItem" Then
 Set oContact = oItem
 With oContact
 .AssistantTelephoneNumber = FixFormat(.AssistantTelephoneNumber)
 .Business2TelephoneNumber = FixFormat(.Business2TelephoneNumber)
 .BusinessFaxNumber = FixFormat(.BusinessFaxNumber)
 .BusinessTelephoneNumber = FixFormat(.BusinessTelephoneNumber)
 .CallbackTelephoneNumber = FixFormat(.CallbackTelephoneNumber)
 .CarTelephoneNumber = FixFormat(.CarTelephoneNumber)
 .CompanyMainTelephoneNumber = FixFormat(.CompanyMainTelephoneNumber)
 .Home2TelephoneNumber = FixFormat(.Home2TelephoneNumber)
 .HomeFaxNumber = FixFormat(.HomeFaxNumber)
 .HomeTelephoneNumber = FixFormat(.HomeTelephoneNumber)
 .ISDNNumber = FixFormat(.ISDNNumber)
 .MobileTelephoneNumber = FixFormat(.MobileTelephoneNumber)
 .OtherFaxNumber = FixFormat(.OtherFaxNumber)
 .OtherTelephoneNumber = FixFormat(.OtherTelephoneNumber)
 .PagerNumber = FixFormat(.PagerNumber)
 .PrimaryTelephoneNumber = FixFormat(.PrimaryTelephoneNumber)
 .RadioTelephoneNumber = FixFormat(.RadioTelephoneNumber)
 .TelexNumber = FixFormat(.TelexNumber)
 .TTYTDDTelephoneNumber = FixFormat(.TTYTDDTelephoneNumber)
.Save
nCounter = nCounter + 1
 End With
 End If
 Next
MsgBox nCounter & " contacts processed.", vbInformation
End Sub
Private Function FixFormat(strPhone As String) As String
strPhone = Trim(strPhone)
 FixFormat = strPhone
 If strPhone = "" Then Exit Function
 Dim prefix As String
 prefix = Left(strPhone, 1)
 If prefix = "+" Then Exit Function
 ' Configured for US
'' ' Enter the correct prefix here
'' Do While (prefix = "+" Or prefix = "1")
'' ' if the prefix is 2 digits, change to 4;
'' ' if 3 digits, change to 5
'' strPhone = Mid(strPhone, 3)
'' prefix = Left(strPhone, 1)
'' Loop
' After we clean up the country code, we remove non-numeric characters
' Can be tweaked to change formatting, ie: change 202.555.1212 to 202-555-1212
 If prefix = "0" Or prefix <> "+" Then
    strPhone = Right(strPhone, (Len(strPhone) - 1))
    strPhone = "+91 " & strPhone 'Replace(strPhone, "0", "+91", 1)
ElseIf prefix <> "0" And prefix <> "+" Then
 End If
'' strPhone = Replace(strPhone, "(", "")
'' strPhone = Replace(strPhone, ")", "")
'' strPhone = Replace(strPhone, ".", "")
'' strPhone = Replace(strPhone, " ", "")
'' strPhone = Replace(strPhone, "-", "")
End Function
This build. Prop on my RAZR maxx, and jb works perfectly
# begin build properties
# autogenerated by buildinfo.sh
ro.build.id=9.8.2O-72_VZW-8
ro.build.display.id=9.8.2O-72_VZW-8
ro.build.version.incremental=26
ro.build.version.sdk=16
ro.build.version.codename=REL
ro.build.version.release=4.1.2
ro.build.date=Tue Dec 11 05:57:08 CST 2012
ro.build.date.utc=1355227028
ro.build.type=user
ro.build.user=hudsoncm
ro.build.host=il93lnxdroid80
ro.build.tags=release-keys
ro.product.model=DROID RAZR
ro.product.brand=motorola
ro.product.name=XT912_verizon
ro.product.device=cdma_spyder
ro.product.board=spyder
ro.product.cpu.abi=armeabi-v7a
ro.product.cpu.abi2=armeabi
ro.product.manufacturer=motorola
ro.product.locale.language=en
ro.product.locale.region=US
ro.wifi.channels=
ro.board.platform=omap4
# ro.build.product is obsolete; use ro.product.device
ro.build.product=cdma_spyder
# Do not try to parse ro.build.description or .fingerprint
ro.build.description=cdma_spyder_mmi-user 4.1.2 9.8.2O-72_VZW-8 26 release-keys
ro.build.fingerprint=motorola/XT912_verizon/cdma_spyder:4.1.2/9.8.2O-72_VZW-8/26:user/release-keys
ro.build.characteristics=default
# end build properties
# system.prop for CDMA Droidwe
# rild.libpath=/system/lib/libril-moto-umts-1.so
rild.libpath=/system/lib/libmoto_ril.so
rild.libargs=-d /dev/ttyO0
telephony.lteOnCdmaDevice=0
ro.sf.lcd_density=240
ro.mot.ril.danlist=611,*611,#611
persist.ril.ecclist=911,*911,#911
persist.ril.modem.mode =1
# This defines the max event window manager can
# handle in 1 s. We may adjust this # for performance
# reason later
windowsmgr.max_events_per_sec=55
# USB modes allowed for UI and switching
ro.ngp_available=1
ro.modem_available=0
# Default network type.
# 7 => GLOBAL.
ro.telephony.default_network=10
ro.com.google.clientid=android-motorola
ro.url.legal=http://www.google.com/intl/%s/mobile/android/basic/phone-legal.html
ro.url.legal.android_privacy=http://www.google.com/intl/%s/mobile/android/basic/privacy.html
ro.cdma.home.operator.numeric=40400
ro.cdma.home.operator.alpha=Reliance
ro.config.vc_call_vol_steps=7
# wlan interface
wifi.interface = wlan0
softap.interface = wlan1
# Time between scans in seconds. Keep it high to minimize battery drain.
# This only affects the case in which there are remembered access points,
# but none are in range.
wifi.supplicant_scan_interval = 180
# Indicate carrier OTA SP number schema
# refer to frameworks/base/telephony/java/com/android/
# internal/telephony/cdma/CDMAPhone.java for the schema:
ro.cdma.otaspnumschema=SELC,1,80,99
# The OpenGL ES API level that is natively supported by this device.
# This is a 16.16 fixed point number
ro.opengles.version = 131072
# The URL for safety information
#ro.url.safetylegal=http://www.motorola.com/staticfiles/Support/legal
# our HTML browser (not WAP browser ) based on requirements IKHSS6-1061 need to specify UAProf URL
ro.mot.hw.uaprof=http://uaprof.vtext.com/mot/xt912/xt912.xml
# Enable HAC to also display Call Setting Menu Option.
ro.mot.hw.HAC=1
# Motorola, a19622, 12/28/2009, IKSHADOW-204 / Location Settings for android
# Property to set enabling state of the location privacy setting feature.
# Motorola, a19622, 03/16/2010, IKSHADOW-2141 / Disable feature 33067
#ro.mot.settings.locprivacy=1
# ERI feature
# 0 OFF
# 1 ON
ro.mot.eri=1
# Motorol,a6889c,02/Feb/2010,IKSHADOW-619
# Proximity Sensor feature
# 0 disable
# 1 enable
persist.mot.proximity.touch=1
# End IKSHADOW-619
# BEGIN Motorola, a22976, 25-Feb-2010, IKSHADOW-702, FID 31841
# VZW Requirement Specifications: NETWORK BASED PLUS CODE DIALING
# 0 disable
# 1 enable
ro.cdma.nbpcd=0
# END IKSHADOW-702
# BEGIN Motorola, a22976, 12-Mar-2010, IKSHADOW-1784, Power Up Tone
# Motorola, a22976, 12-Apr-2010, IKSHADOW-3298, Remove temporary power up tone
# persist.mot.powerup.tone=/system/media/bootup.ogg
# END IKSHADOW-1784
persist.mot.usb.mediasync = 1
# persist.usb.android_config = 1
# System property for Security Middleware Component
ro.service.start.smc=1
ro.HorizontalBUA=true
#Proximity sensor debounce time
mot.proximity.delay=450
# disable touch below 60 pixels
mot.proximity.distance=60
# BEGIN Motorola, qpmc46, 05-Jul-2010, IKMAIN-311
persist.ril.mux.noofchannels = 8
# END Motorola, qpmc46, 05-Jul-2010, IKMAIN-311
#BEGIN Motorola, nfjb73, 21-jun-2010,
# this is for feature 34386, other features for vzw global phone
# could use this property too. IKMAIN-732
#1 this is verizon wireless globle phone
#0 this is not verizon wireless globle phone
ro.mot.phonemode.vzwglobalphone=0
# END Motorola, nfjb73, 21-jun-2010, IKMAIN-732
# BEGIN Motorola, nfjb73 23-jun-2010, IKMAIN-624
# this is for feature 33860, when phone is activated, the cdma mdn is written.
persist.radio.vzw.cdma.mdn=9376179177
# BEGIN Motorola, qmfd78, 14-Jul-2010, IKMAIN-884
# GSM SMS traffic needs to be routed/sent through North America SMSC.
# This is part of the VZW World-phone Feature. SMS are always sent to a US SMSC and then injected
# into that network. This allows for billing and give the user the impression that the device is
# still in the US.
ro.telephony.gsm-routes-us-smsc = 0
# END Motorola, qmfd78, 14-Jul-2010, IKMAIN-884
# BEGIN Motorola, a22600 qmfd78, 16-Jul-2010, IKDROIDPRO-423
# For north american cdma operators, this flag should be 1.
# It enables number mangling when nbpcd (plus code dialing) is not supported.
ro.cdma.home.operator.isnan=0
# END Motorola, a22600 qmfd78, 16-Jul-2010, IKDROIDPRO-423
# EDM feature - IKDROIDPRO-381 - Start
ro.mot.dpmext = true
# EDM feature - IKDROIDPRO-381 -End
# BEGIN Moto,IKDROIDPRO-430, a17673
# Feature33857 on DroidWE, support DualMode switch, UMTS/CDMA
##### Override in cdma_spyder.mk until LTE + Global support. ######
#ro.mot.FTR.33857=true
# END IKDROIDPRO-430
# This is necessary for framework to support
# the LTE and eHRPD capability.
#ro.mot.lte_on_cdma=1
# BEGIN Moto, IKSTABLETWO-1284, nfjb73
# without this property, the lock screen would take global phone as UMTS
# block user to operate before setup
keyguard.no_require_sim = true
# End Moto
# BEGIN Moto, IKSTABLETWO-689, nfjb73, for 34387,33857
# when phone in Global mode, FW need to know the last phone mode beore power off
# when phone power up, it would use the right mode to avoid switch
persist.radio.ap.phonetype=2
# END IKSTABLETWO-689
# Multimode RIL Paths
#lte_ril.libpath=/system/lib/lib-mot-lte-ril.so
#cdma_ril.libpath=/system/lib/libmoto_ril.so
#ril.rat=LTE
# BEGIN Motorola, hwqc67, 22-Jun-2011, IKLOCSEN-317, FID 36426
# Gps Smart Battery Savings
# (depends on sensor hub)
# 0 disable
# 1 enable
persist.mot.gps.smart_battery=1
# END IKLOCSEN-317
# Motorola, IKHALFMWK-3, w001091
# Feature 32711, deep sleep mode support
ro.mot.deep.sleep.supported=true
# Give extra time for LTE bug dumps
ril.dumpstate.timeout=60
# BEGIN Motorola, a22543, 16-Aug-2011, IKSTABLE6-8304
persist.dbg.kwdt.report=0
# END IKSTABLE6-8304
# BEGIN Motorola, w15439, 19-Aug-2011, IKSTABLE6-9125
ro.hdcp.support=2
# END IKSTABLE6-9125
# BEGIN Motorola, atzakis, 12-Oct-2011, IKSTABLE6-18830
ro.mot.hw.navkeyboard.devname=cy8c201xx
# END IKSTABLE6-18830
# BEGIN Motorola abp095, 4-Jan-2012, IKHSS7-2427 - Thumbnail property change
com.motorola.cg.lowres=1
com.motorola.cg.tnWidth=160
com.motorola.cg.tnHeight=160
com.motorola.cg.tndisplay=1
# END IKHSS7-2427
# system prop for requesting Master role in incoming Bluetooth connection.
ro.bluetooth.request.master=true
# system prop for Bluetooth Auto connect for remote initated connections
ro.bluetooth.remote.autoconnect=true
# System Properties for enabling individula Bluetooth Profiles
ro.qualcomm.bluetooth.opp=true
ro.qualcomm.bluetooth.hfp=true
ro.qualcomm.bluetooth.hsp=true
ro.qualcomm.bluetooth.pbap=true
ro.qualcomm.bluetooth.ftp=false
ro.qualcomm.bluetooth.map=true
ro.qualcomm.bluetooth.nap=true
ro.qualcomm.bluetooth.sap=false
ro.qualcomm.bluetooth.dun=false
ro.mot.btdun.disable = false
# ADDITIONAL_BUILD_PROPERTIES
ro.com.google.clientidbase=android-motorola
ro.com.google.clientidbase.ms=android-verizon
ro.com.google.clientidbase.am=android-verizon
ro.com.google.clientidbase.yt=android-verizon
ro.com.google.clientidbase.gmm=android-motorola
persist.sys.usb.config=mass_storage
ro.kernel.android.ril=yes
persist.ril.mux.noofchannels=10
persist.ril.mux.ttydevice=/dev/ttyO0
persist.ril.modem.ttydevice=/dev/usb/tty2-1:1.4
persist.ril.tcmd.ttydevice=/dev/usb/tty2-1:1.3
persist.ril.diag.ttydevice=/dev/usb/tty2-1:1.0
persist.ril.features=0x90A
persist.ril.mux.retries=500
persist.ril.mux.sleep=2
persist.ril.rssi.enable.param6=1
ril.wrigley.modem.tty=/dev/usb/tty1-2:1.10
persist.radio.lte.mm.disable=0
rild.libpath=/system/lib/moto-ril-multimode.so
gsm.sim.mot.simswap=1
ro.config.ringtone=DroidInvasion.ogg
ro.config.notification_sound=Droid.ogg
ro.mot.build.customerid=verizon
ro.mot.build.version.sdk_int=9
ro.mot.build.product.increment=2
ro.mot.build.version.release=9.2
ro.build.version.full=Blur_Version.98.72.8.XT912.Verizon.en.US
ro.mot.hw.HAC=1
ro.setupwizard.mode=OPTIONAL
ro.com.google.gmsversion=4.1_r3
ro.HorizontalVVM=true
ro.horizontalNGM=false
ro.horizontalVMM=false
ro.horizontalMOD=false
ro.horizontalVOD=false
ro.horizontalEmail=false
ro.cdma.home.operator.numeric=310004
ro.cdma.home.operator.alpha=Verizon
ro.cdma.homesystem=64,65,76,77,78,79,80,81,82,83
ro.mot.eri=1
ro.cdma.nbpcd=0
ro.mot.ignore_csim_appid=true
ro.telephony.gsm-routes-us-smsc=0
ro.mot.phonemode.vzw4gphone=0
ro.com.android.dataroaming=true
ro.bug2go.uid.type=TELEPHONY_DEVICE_ID
ro.bug2go.magickeys=24,26
ro.carrier=unknown
ro.config.alarm_alert=Alarm_Classic.ogg
dalvik.vm.heapsize=128m
dalvik.vm.heapstartsize=8m
dalvik.vm.heapgrowthlimit=64m
ro.cdma.subscription=0
ril.rat=LTE
lte_ril.netcfg_to=90
ro.telephony.call_ring.multiple=false
ro.cdma.data_retry_config=max_retries=infinite,0,0,10000,10000,100000,10000,10000,10000,10000,140000,540000,960000
ro.gsm.data_retry_config=default_randomization=2000,max_retries=infinite,0,0,80000,125000,485000,905000
ro.gsm.2nd_data_retry_config=max_retries=infinite,default_randomization=2000,0,0,80000,125000,485000,905000
ro.mot.setuptype=2
ro.horizontalIM=true
ro.ril.svlte1x=true
ro.media.camcorder.1080p=mp4,h264,30,15000000,aac,128000,44100,2
ro.media.camcorder.720p=mp4,h264,30,10000000,aac,128000,44100,2
ro.media.camcorder.d1NTSC=mp4,h264,30,6000000,aac,128000,44100,2
ro.media.camcorder.vga=mp4,h264,30,4000000,aac,128000,44100,2
ro.media.camcorder.cif=mp4,h264,30,1500000,aac,128000,44100,2
ro.media.camcorder.qvga=mp4,h264,15,500000,aac,64000,44100,2
ro.media.camcorder.mms=3gp,h264,15,128000,amrnb,12200,8000,1
ro.media.camcorder.mmsres=qvga
ro.camcorder.zoom=true
ro.media.capture.maxres=5m
ro.media.capture.fast.fps=4
ro.media.capture.slow.fps=120
ro.media.capture.flash=led
ro.media.capture.flashMinV=3300000
ro.media.capture.torchIntensity=40
ro.media.capture.flashIntensity=100
ro.media.capture.classification=classF
ro.media.panorama.defres=3264x1840
ro.media.panorama.frameres=1280x720
keyguard.no_require_sim=true
ro.media.enc.aud.fileformat=qcp
ro.media.enc.aud.codec=qcelp
ro.media.enc.aud.bps=13300
ro.media.enc.aud.ch=1
ro.media.enc.aud.hz=8000
ro.mot.lte_on_cdma=0
ro.mot.tmp.telephony.refactor=true
net.bt.name=Androidt
dalvik.vm.stack-trace-file=/data/anr/traces.txt
drm.service.enabled=true
