Vinod Nayak
Samsung Galaxy Note II GT-N7100 Wireless Charging Mod
The same mod can also be done for the earlier model Samsung Galaxy Note GT-N7000 provided the phone is physically sent to me. It takes an hour to finish the mod.
Sent from my SPH-L710 using Tapatalk 2
Good to see such initiative from a fellow rimwebian. Keep it up, great work....
Sent from my DROID RAZR using Tapatalk 2
Now you can change your handle here to "Induction Charging Guru" Great work Sirji...
BTW the 2 contact points on cover , are they inbuilt??
Yes inbuilt NFC.
Vinod Bhai,
Sorry If i sound naive,
is this GSM +CDMA or CDMA only . Also pls confirm RUIM capability
This is GSM. It does not belong to me. My relative loaned it to me for a day to test out the wireless charging mod. Parin Bhai should be able to help you with your query.
Great job! Good to see innovation! Hope to see more of such stuff. By the way, why is it restricted to Note II only? Why not for other devices too? Any particular restriction considering it is a hardware mod and not limited to the phone itself?
Regards
Rahul
Right now only S3 and Note 2 have the wireless charging ports built in by the company. I have managed to do the same on Epic, Epic Touch, S3, Note and Note 2. Only S3 and Note 2 phones can get the wireless mods without opening the phone since the wireless charging ports are built in. The rest of the phones have to be opened up.
Can we do something like this with a Palm pixi plus back cover and Touchstone? I've one lying around - would be of good use :)
for palm pixi plus, the company released touchstone back covers and they are available. just change the back cover with compatible touchstone back cover. it will work with touchstone charger. If you could not found them. pm me. I will help in getting them for you.
