Jignesh_patel6744
Recover (Not Starting) Verizon Samsung Fasinate i500
I have Samsung Fasinate i500 Verizon,
When i start the mobile, It shows the samsung logo only, it does not go ahead and stucks there only.
So i assume its going into booting loop, Please help me with recovering it and also with the links for files to be downloaded.
It was running on GB 2.3
Same issue here. Tried flashing 3 different tar files.. Still a no go. Can go only into download mode! :(
Download eh03 odin tar
Check md5
Download atlas pit
Flash both together via odin thru download mode and via pda option.
It should get fixed.
Get the files in this post.
The guy has quoted my pm
http://www.rimweb.in/forums/index.php?/topic/32723-Update-Verizon-Fascinate-i500-to-Gingerbread,-Ice-Cream-Sandwich-and-Jellybean#entry279602
sent from my NOTE II, yupp size does matter.
Edited by joshm
  • Like 3
Thank you joshji. That worked perfectly fine. Now its up and running! :cheers:
Sent from my SPH-D700 using Tapatalk 2
Happy to be of use dear mates.
:D:D:D:D:D:D
