sadanand.sapkal
How to open PC when not accepting Password
Dear Friends,
I am not able to open my PC with the set password. I have not changed its password, still the given password showing incorrect.
Kindly guide me the simplest way to resolve this issue.
Thanks in advance.
Regards,
Sadanand Sapkal
Little more details please
Which password ?
System bios password
Password on win xp / 7 / 8 etc
Linux / Mac ?
Sent from my Moto G using Tapatalk 2
Create a USB bootable using Sardu or any other
http://www.sarducd.it/
http://4sysops.com/archives/build-a-bootable-windows-pe-3-0-usb-drive-with-rescue-tools-part-1/
then use this
http://4sysops.com/archives/free-ntpwedit-reset-windows-password/
it resets your password there are various utility in sardu itself
be careful in installing sardu it also installs bad addware so use waste machine.
  • Like 3
Dear Hitesh Ji,
I am talking about password which we set thru control panel and needs to put while we start the pc. I am using acer netbook with Windows 7.
Here is few more ways
http://m.wikihow.com/Recover-Windows-7-Password-With-Chntpw-USB-Disk
http://www.pendrivelinux.com/usb-ophcrack-windows-login-password-cracker/
Edited by ::Hitesh::
I second chntpw, works almost every time.
Just remember to change directory into the correct folder before running it. (search for SAM inside windows folder and cd in the folder containing SAM).
If you have a problem making bootable pendrive for any of the above solutions, you can borrow one from me if you are passing through Bandra WEH any time.
If you are only worried about the data you can copy it by booting any live CD or even windows set up CD and pressing Alt F10 to get a shell then type explorer to copy data to any pendrive etc.
BTW, I once had a similar problem and discovered that the keyboard localization had changed to UK and instead of the symbols (in my password) it was typing something else.
You can check that by typing your password in the LOGIN box once (don't press enter, just type and see).
Thanks All.
Finally Today I got success to open my pc with my same old password.
As suggested by ami1, there was some Keyboard problem. I have selected the OnScreen keyboard and typed the same old password with the help of onscreen keyboard and the things got solved.
Now searching on Google for restoring many Key board setting to default.
Thanks all again for helping me out on my problem.
Regards,
Sadanand
