Kalaichelvi
Sprint Note 4 Incoming SMS problem
hi Gurus,
Posting on behalf of a friend here.
He is using a sprint Note 4 and have issues getting Incoming SMS in CDMA.
The outgoing sms is fine.
It works with GSM also without any issues.
Can any one throw some light on the SMS issues with cdma ? ... Please help.
This cannot be solved! Please read the forums.
That's crazy.. Every high-end cdma phone one buys, they need to make a list of all the basic functions of a phone & check with their seller.. This works.. Ahh. How about that one..
I am going get my sprint note 4 today. I will check and post here about SMS.
Just now I checked I am receiving SMS on CDMA. both from other mobiles and cell company sms. I used TATA Docomo CDMA sim in Note 4. Even In GSM DATA, voice, and SMS is working.
Edited by Guru Gopal
In dfs I put the phone in ruim pref and loaded reliance prl. I also write a old NV dump file with NV writer. That's all I did. But I am Not getting REV.B. only getting REV.A. I will check in other towers also in next 2days and update. I unlocked GSM with apk.
AFAIK, Samsung has never manufactured any Revision B handsets. Popular ones are LG and HTC and some rare ZTE and Huawei models.
Sent from my Droid Turbo
Can u check with Reliance sim?
Any body can give the CF auto Root file for this N910p phone. I could not get it for 5.0.1. The old file meant for kitkat is not working.
Gopal ji? Answer for the previous post please?
Dr Faramrose
Note3 and Note4 S5 all works on Rev B just put proper EVDO type
Dr Faramrose
But again SMS issue persists right?
Sent from my Motorola Droid Turbo using Tapatalk 2
Dr Faramrose
can u give guidance how to put proper EVDO type.
Use RGERUC series reliance sim in sprint note 4g to fix sms incoming problem.
Hi pretam, Can you explain any way to get REV.B on this Note4 for reliance or Docomo
Using RG series reliance CDMA SIM I did not face problems. I checked SMS in coming and outgoing working fine, apart from Echo and voice
What is the difference between RECRUC06 series and RG series?
I have a Samsung Mini (SPH-L520) phone. SMS does not work on it. Whenever, I absolutely need messaging, I'll put the SIM card in my old Lenovo phone get the messages, and then put the SIM card back in Samsung Mini phone. To my surprise, the incoming SMS works on the Samsung phone for few hours after I move the SIM from Lenovo phone, and then I cannot receive anymore messages.
I had been struggling with this problem for several months now. Could this be due to a different series of SIM cad? Is there some programming that needs to be done (something forgotten - calls and data work well on Samsung phone)?
-PK
Where do i get this series ? Or have the been made to vanish from the stores ?
Here is my Note 4 working with EVDO Rev B. In Mumbai.
Which series SIM?
REC series. Incoming SMS problem on this series. Will check with RGE later and update here.
guys where can i get the RGE series sim ?
Million Dollar question.
Get close to someone from WW, make them friend, treat them, make them happy and then finally ask for SIM....they might give it(if they have this series and understand that there are different series SIM available!!)
Jokes apart, very difficult, you need to check at WW only whether they have RGE sim stock or not.
how u getting EVDO revB..
even m frm mumbai but nt able to get ..
can u plz help..
using sim series RUC
Any update for the SMS issue being resolved (on Touchwiz based ROM)
