huaweitrick
Reliance Pro 3 Speed Test
Reliance Pro 3 speed test
Reliance promising upto 14.7 mbps speed
i created this post regarding RELIANCE PRO 3 speed.
members can post there speed test result of reliance pro 3 data dard here.
so that other peoples are aware of it the speed they r going to get after buying reliance pro 3 data card.
after past 1 month i had seen the issues is in there connectivity with mts network.
places i had tested in delhi
from nehru place to jasola
speed is very good 5.5 to 7 mbps in reliance rev b
karol bagh metro station - 3.1 to 4.1 mbps
near
pritampura metro staion
speed in night - above 3.1 mbps
in day speed is only 1 mbps.
in delhi i had tested only these places
it takes 1.5 to 2 months
problem in there conectivity with each other network.
others state's people can also post there speedtest result here
it will help to others people too.
sent by - huaweitrick02@gmail.com
recently tested at nehru place (new delhi)
in which device you are using pro 3 ? giving such good speed 5mbps really great.
dwarka metro station ( new delhi )
Is the 999 plan on reliance pro 3 truly unlimited? Has anyone in chennai used/using it? If yes, feedback regarding speeds would be appreciated.
no its a cap of 40 gb then 2g
what about 949UL plan is it work on Pro3 network on normal Evdo working sim?
Is rev b data it unlimited in 949/-, 2799/- and 4999/- prepaid ?
yes in this plan data is unlimited
I am also the subscriber of this same Reliance Pro 3 data card. But this one is giving poor speed at my home in sector 7 Gurgaon area. only upto 1Mbps in day, upto 2Mbps in night.
Also, the 999 truly unlimited exists but only for few locations like mumbai, pune, bangalore etc. not in Delhi Gurgaon circle.
Yes, this plan data is unlimited in mumbai also & It is with without roaming charges.
hello friends from several days i had not checked evdo b .
handset model htc 510 sprint
evdo B WORKING fine in various part of delhi with reliance
speed in day time around
2.1 mbps to 3.5 mbps
@ night above 3.5 mbps
sent by :- huaweitrick02
Hi Dear,
Second pic shows you are connected to wifi.
Delhi as discussed earlier is having Rev B evdo in ICR with mts, how come ruim is then supported, please guide others as well.
Also mention locations where you received this speed.
Regards
i m using htc 510 in non sim
i have 2 phone
1 is samsung grand max
2 is htc 510
using reliance unlimted plan
i use htc 510 as a wifi hostspot and calling...
that why second pics is samsung.
i have 2 phone
2 is htc 510
Thanks Dear but the mystery remains unsolved, which prl are you using and since in Delhi it's ICR with mts, guide other members as well how to get Rev b
Regards
