Update your software. VoLTE feature was introduced after the update AFAIK.
Then manually enable VoLTE in Mobile networks.
Already running Nougat.
Volte provision flag doesn't stick to enable. Keeps switching off itself.
Sent from my Nexus 6P using Tapatalk
Enable VoLTE and reboot.
For volte to work IMS registration is required
Enable IMS registration in this  @shivaagarwal1
Edited by kuduku
9 hours ago, shivaagarwal1 said:
How to? Please guide.
It is done from the Phone Info whose screenshots , you posted . If you cannot enable it then Volte is not enabled in stock firmware ,
till its enabled by a firmware update you cant enable it
That's said.. Neither google nor Huawei is helping on this.
See the screenshot.
Please remove your IMEI number from the snapshot..
