rahuldixit2010
Jio VoLTE on AT&T Samsung Galaxy S7
31 posts in this topic
Can anyone help in enabling VoLTE on foreign handsets. I have AT&T Samsung Galaxy S7 edge which support all three LTE band of Jio , but VoLTE doesn't work.
In status it says "IMS not registered". Any help?
How to enable VoLTE explained here
http://www.androidcentral.com/how-enable-volte-galaxy-s7
Edited by LTE4G
You may trying enabling volte but for now non Indian handsets won't work in jio network till December end
They are working fine with foreign handset too. Using Jio sim on Sprint Moto E and not having any issues, been over couple of weeks.
Sent from my XT1031 using Tapatalk
The VoLTE is enabled but it is not working. VoLTE sign doesn't come. Data is working fine.
Does VoLTE work on it. Did you purchased new sim or old jio sim which got activated in other phones.
There is no issue with the SIM (Old & New). Did you follow the instructions as given below ?
How to enable HD Voice and Video Calling (VoLTE) on an AT&T Galaxy S7
  1. Launch the Settings app from the Home screen, app drawer, or Notification Shade.
  2. Tap Mobile networks.
  4. Tap Enhanced LTE Services to enable HD Voice.
  5. Tap Video Call.
  6. Tap the switch to turn on Video Calling.
Edited by LTE4G
How to enable HD Voice and Video Calling (VoLTE) on a Verizon Galaxy S7
  2. Tap Advanced Calling.
  3. Tap Advanced Calling (Turn on/off..) to enable HD Voice and Video Calling.
  4. Tap the switch to turn it on.
  5. Tap and select HD Voice and Video Calling from the option.
  • HD Voice and Video Calling
  • HD Voice only
Edited by LTE4G
How to enable Voice over LTE (VoLTE) on a T-Mobile Galaxy S7
  2. Tap Applications.
  3. Tap Phone under Application settings.
  4. Tap the switch next to Voice over LTE Preferred to turn it on.
Edited by LTE4G
  5. Tap Video Call.
It is enabled but doesn't work. In device status it says IMS not registered.
I tried enabling VOLTE on my Verizon S7 but every time got a failure message.
All these don't work on this this, have same, tried all tricks
Tried AT&T, t-mobile, Verizon roms still no volte
Tried flashing Indian csc from xda using flashfire but doesn't work
No twrp for Snapdragon model so flashing roms etc using flashfire app only
Even after flashing Unlocked 930U Version no volte
AT&T volte shows selected but doesn't work
Edit : seems might work with this csc
http://forum.xda-developers.com/showthread.php?p=68953189
Sent from my SM-G930U using Tapatalk
Edited by kuduku
IMS registered can be easily changed using NETWORK app or *#*#4636#*#* , but still doesn't work
Yes it doesn't work,  on  *#*#4636#*#*  it shows enabled and in setting also HD voice is ticked but of no use. I have AT & T S7 active also with same issue. Still in Device Status it show "IMS not registered".
lets hope something emerge out as solution for jio.
Did you enable "use VoLTE when available" from Dialler ->> More ->> Settings ->> VoLTE
If so, then the phone is not fully unlocked and IMS is locked with the original carrier and will not get registered with any other Network.
yes, it enabled from settings. AT&T it is under Data Setting in the name "Enhanced LTE Services". The phone is full unlocked, but then also it is not working.
Guys sorry to say but you are all going about it slightly off direction. Having all supported lte bands unlocked and volte feature enabled in your phone is simply not enough.
VOLTE works only and only on devices that the carrier explicitly supports. Your imported handsets are unlocked but model numbers would never match on your Indian carrier. You can benefit from LTE data and jio4gvoice app.
Sent from my MI 5 using Tapatalk
1 person likes this
okay, it mean jio can enable the volte in case they want?
But the question is, why will they go the extra mile to enable them in their networks, especially when they already have their own phone co?
sent from my Lenovo vibe P1 using Tapatalk
Because when they say their network will work with Volte phone for voice, they should ensure all compatible should work on their network.
Still volte doesn't
Sent from my SM-G935A using Tapatalk
4 hours ago, kuduku said:
Still volte doesn't
how did you flash other csc rom in your phone? through flashfire?? if so, do one thing. soon after finishing, reboot to your stock recovery. it`ll show which csc is active. then do a factory reset and reboot. reply here if working and hit thanks pls
Manually inserted csc in ROM before flashing it using flashfire
Can't flash csc using cscflasher as the zip only works on exynos procs
Will check recovery & update here
Sent from my NX518J using Tapatalk
Attaching the recovery pic
Where's the csc details here
What does factory reset achieve here. Just set it up completely with all apps.
thats what helped me in my s6 edge bought from singapore. eventhough bth here and Sg the model is g925i. i had to flash INU csc version to get volte. even after flashing that, i had to do a factory reset in stock recovery so that the CSC changes to INU.
P.S: it usually shows csc in the bottom above the single-sku. btw check your cscversion.txt and softwareversion.xml in system folder if it corresponds to your model number.
