mauk
JioFi sim and other hotspot device
Is it possible to use JioFI sim on any other hotspot devices? If yes, can you recommend any.
Regards,
You can buy airtel unlocked 4g modem from ebay and you can use it as hotspot
Thank you. Could you suggest good models of Airtel that might work?
^ They might throttle your speeds if you use non-supported devices. Two of my connections got throttled, to around 200-250 Kbps. When I called them they said the device (they had the correct model number of the device on their end) isn't supported and they cannot help me with it.
I inserted the sim in a 4G handset, the speeds were restored to the usual (slow) speeds in 1-2 Mbps that I get usually.
