Dipankar Bhattacharya
Help required in rooting LYF F1S
Well you can start by going to developer options and taping the unlock OEM option..Then use kingroot app..It should work..But be aware of what you are about to do with your device and stay ready if anything goes wrong.Also I don't know about Lyf's software policies but usually brand warranty gets void after rooting...Cheers✌
Edited by Aakash1605
