Shabz
USB Not recognised / USB-Serial Converter
:D HI Can we use the bitpim software with USB cable I tried but could not find the system file always error comes
Please help me
I am not sure...
but i dont think it supports usb cable... :rolleyes:
Maybe if u try twice it would show up...
Ok guys i m havin a slight problem with Bitpim..
I am using a USB port and have both the versions of Bitpim.. i.e. .62 and the test version 7...
Now it is unable to detect my phone.. like shabbooo problem.. what to do??
has anyone managed to get RD 2030 and bitpim working with a USB cable???
Can this software and files be used for a RD7130 colour handset if yes can u please let me know the procedure and if usb doesnt work with RD7130 then can serial cable work to download the ringtone to it - NCODERG please reply to me.
Well
About the other models - I only have RD2030 so i cant tell you much about the others . :) .. By the way one of my friend says that USB + bitpim work ;)
yes u can use usb cable. i'm using a usb cable. use the instructions given in the tutorial n keep on retriving files till ur pc reads from the phone. hey guys any idead how to upload wall papers??
Hi ppl..
This is my first post on the grp..
i some how (v v luckily) reached ngcoderg website.. and found the way to upload ur own ringtones to rd2030... kewl...
then found my way to this kewl forum as well..
now immediately i went on to try the uploading of the ringtones...
BUT
but i have a usb cable (the same one that reliance guys provide in the webworlds - costing Rs 1200)...
i do not know how do i use it with bitpim..
tried going trhu posts on the forum.. some where some one mentions "go thru the tutorial".. but then could not find the tut itself..
can some one pls pls explain me how do i use this cable.. :help:
great..
Thx
rahula
Hi There
I have a lg rd2030 and an original Reliance USB Cable
Ever since i heard i could hack the phone with USB Cable I have been trying like hell to access the filesystem .
But i still dont seem to get it right
How about a step by step guide for USB users on how to Hack the 2030
including what should be the bitpim settings and everything
the bitpim HELP said i will need libusb-win32 driver for usb cables so i downloaded it but still didnt work .
Can anyone tell me if the driver is necessary . If not then which COM port to choose in the settings .
The program shows COM 1 and COM 2 in the settings but both dont work when i try to open the filesystem
I also have no idea which phone model to select in the menu .
Someone who has already hacked with a USB cable please help
I am sure most of the 2030 users use USB and many must be facing this problem.
Thanks in advance
If you are having a USB Cable, you need to have USB > Serial converter driver..
After installing it, a new COM port will be added to the list other than the current ones..
In Bitpim, you have to select the COM port which is installed by the driver..
Can you give me a link to where i can find the driver
if the driver you are talking about is the libusb-win32 driver then
I have already tried it but it doesnt seem to work.
Come on Guys there are so many entries here by people
using USB cables for help but not one satisfactory reply
every reply says rd 2030 + USB works
but nobody says how
somebody please help
You just have to install the USB - > Serial converter driver
which i think is available for download with Reliance :ph34r:
Then a new COM port will appear, which transmits data to your USB
pretending as a COM port..
In Bitpim, Select Edit > Settings
In that select the Com port which was installed by the driver
Tats it..
Now follow the steps in the tutorial by ngcoders
RD-2030 Ringtone Tutorial
User "Chandramauli" was able to do this way..
Maybe anyone having USB, can say anything more..
I think the software comes with the R-Connect CD..
I am having serial cable.. So cant say much on USB.
Try getting the latest driver here
LG RD 2030 Interface : USB
Uninstall the old and install this..
See whether it works this way :ph34r:
Hi There
But i still dont seem to get it right............
Hi Scuzzy,
Maybe I could help you.
I installed R-connect software in windows XP.
Then I installed Bitpim ver 6 (NOT the latest version 7). You need not install any other drivers etc if your rconnect is working fine. It already has a usb-serial converter (or whatever...does'nt matter to me as long as it works fine).
So, in short, if your rconnect is working in win XP, then you just need to install bitpim ver 6.x and you should be able to access lg rd 2030file system...and do all those things mentioned in this forum.
and mind all of you guys, i'm not at all a techie...I just use common sense!
hope it helps you Scuzzy,
all the best!
ok the usb finally worked
I guess the driver on the Reliance CD was old
when i downloaded the new drivers from the link given by ashok
bitpim showed the com 3 port and i could connect
Thanks Ashok
Get phone data.. ERROR!!!
retrieve file structure ERROR!!!
Dont use the feature Get phone data
It wont work..
Open Bitpim
Select the tab named "Filesystem"
Click "/"
It shows a error ( if not 0.62 )
Click "/" again
Now it gives you the file structure :D
hi,
I have a Windows XP with LG RD2030 mobile. I have recently bought a cord to connect the reliance cell and make use of the Rconnect service. However Windows is not recognising my CELL and enabling it as a modem even after I ahve installed the LG USB drivers and RIM related software on the machine.
Please help
Regards,
Rohit
Junta,
Thanks for the very enthu reply to my query, but we seem to have got lost from my original question:
1) I am using Windows XP on a Vaio laptop
2) The data cable and phone modem is not getting recognised even after I installed the LG RD 2030 drives on the the laptop
3) I checked the laptop and it does not have any serial ports (has a LPT though)
4) I did a scan for new hardware and no serial ports are identified
5) I downloaded BitPim and tried to make it work, it gives the same message that serial ports are not found.
Please advise how to make the cell work on USB. I am trying to RConnect.
Regards,
Rohit
Wat i meant was the same..
Once you install the drivers a new port will be displayed as COM port which is
actually transfering data through ur usb..
One the drivers are properly installed, it com port will come in Bitpim also.
Did u try the new drivers? :confuse:
Isnt it working the latest ones too :P
hi,
I updated the machine with the new USB driver provided from RIM. However the only additional step that I got was for activating RConnect i.e. by calling *412
but the problem is that my LG RD2030 is still not being recognised by the laptop and I am getting a message of unkown USB device.
Any suggestions?
PS: Can I get RConnect disabled till this thing is resolveD? Dont want Dhiru ka sapna to make my money uska apna! Is the RConnect enabling adding some monthly fee?
Regards,
Rohit
R-Connect there is a monthly fee of Rs200
hmmmmm ok... how to get it disabled?
Ok, I also tried one more thing, downloaded XP Patch for USB 1.1 and 2.00 but they did not have any effect
