abhi1kumbhat
Reliance RUIM card for R-UIM slot enabled handsets
Please give me details about RUIM card, like...
how can we use it ?
can we use it with tata handset ?
can we use it with international cdma handsets ?
Thanks.
Answers for all your questions are YES.
On reliance you may not be able to use R WORLD and MMS if handset is from other service provider.
What??? By RUIM, we can use Tata's T-Sim enabled handsets??? kshah, can u pls confirm this? Coz I am planning to buy Samsung Neo for my bro, but I want Reliance as provider.
Thats Possible ani_meher..
I have seen Reliance handsets working on Tata and vice versa !
well so can we purchase handsets from tata and then use it on RM, but how to get ruim from RM.......
Its Easily Available these days.. Check out with the WW or munnamobile !
Reliance does not give RUIM separately. It gives these RUIM cards only with the purchase of RUIM enabled handsets. So to get a RUIM, you have to buy a Nokia 6265.
Correct me if I am wrong.
CC says that only Gtran has RUIM card and it is not available seperatly
it is bundled with set
I am searching for a PDA with CDMA phone that is compatible to use with this Reliance RUIM Card. Please can somebody suggest some international brands?
Thank you :D
Edited by drspking
contact Kshah
contact Kshah
hi
just one major doubt.
cannot understand the jargon surrounding RUIM
can i use RAZR on reliance using UIM card of reliance
RELIANCE has started giving UIM cards.
in this case is it possible for me to use any good pda cdma phone with ruim slot, n reliance network in india.
can i get the phone from US.
ITS OK IF I CANNOT USE RWORLD AS PDA features are more important to me .
HOevevr can i use internet thro the new mobile in this case
jjj
Yes, R-UIM slot enabled CDMA handsets can work with the R-UIM cards supplied by Reliance. I belive Ashok Karkera is already using Reliance on his Chineese Nokia 6275i :grin: And yes, R-World won't be there, anyway who wants it :P
thanks for your reply buddy.
just one thing, can i use the internet in this case...
tks
will wap work on such handsets?
I mean we have at least two handsets that have minibrowsers (6255 and 6235) but it can not be used because it is not allowed by reliance.
Now say if I get a RUIM enabled handset from abroad and then I am not able to use wap on it?
What use will an imported handset be if I can not access net on it?
Can someone clarify?
Network connection on any handset appears to be controlled by SHARED SECRET (Known as SSD_A and SSD_ :P When I changed SSD key in my 6155, it could not connect to WAP or PPP. If how SSD key is calculated is known I think WAP can be used on any handset.
Right now I have RUIM but do not have RUIM handset, so I am unable to conduct any trials. I will post any findings If I get RUIM handset.
I think Ashok can shed some more light on this
I need A RUIM Card for mine Current Number... Is it possible to get from reliance WW or any guy in Mumbai Area Could help me out ... I am ready to pay Cost For the RUIM Card...
Contact me by mail or pm me ...
I'm not sure of WAP... but if you are buying a R-UIM slot enabled CDMA Smartphone, you should be able to use its full fledged browser through Net Connect (R-Connect).
Well RUIM sure rocks, tried it on a Nokia 2225 , a Nokia 6275i, a goldstar and even a WinCE Handset ( the make of which cannot be divulged as of today :help: )
the nokia 6275i I just sold ... but here are a few pics of the other nokia :help:
The Nokia 2255
Service Provider Name (from the programming menu)
The Back label (of course personal info edited... but u can see clearly that it is a test phone as well as the proto version)
The Reliance RUIM
cheers
ashok
Can I get d (for Ruim card) whole process how can i transfer my no which is on nokia 3125 presently.& where i get blank ruim as it is not avalable in our area.
RUIM cards are available in many places now. RUIM cards come with a connection as far as I know. So transferring a number may not be possible. My friends in Mumbai and Vadodara have reported it as available in their places and is available for just Rs.50 only.
:( ( I spent Rs. 200/- on the RUIM thingy :!!! (but have 4 numbers on RUIMs now .. including my 2 year old number.. :lol:
cheers
a
s :thumb:
h o k
Hi Ashok, I have one Nokia 2280 without any number, but RIM handset. How do I enable the RUIM slot. Also if I put in the TATA UIM card, will it operate, if NO then how to make it work.
Regards,
Jignesh
