meacapo
Problems With Sync
Hey friend ,
I have been facing two problems, can you guys help me ,
1.
after sync i get this message on the log
Backed up some files successfully to Ciril Michael's Backup folder
  • Duration: 12.4 seconds
  • Backed up 41 file(s) successfully
    • AddressingLibRecent-HsCh
    • Blazer Bookmarks
    • CarrierProfiles2
    • locLDefLocationDB
    • ConnectionMgr50DB
    • NetworkDB
    • locLCusLocationDB
    • MMIDCache0
    • MMIDCache1
    • MMIDCache2
    • MMIDCache3
    • MMIDCache4
    • MMIDCache5
    • MMIDCache6
    • MMIDCache7
    • HSTraceDatabase
    • midataidcache
    • Messages Database
    • NetworkProfiles2
    • SndFile Ring Tones
    • MSLSA Data
    • Blazer URL Autofill
    • Blazer Field Autofill
    • Package Installer
    • AddIt
    • BFVaultDatabase
    • PhoneCallDB
    • Cookie Data
    • AddressCitiesDB
    • AddressCompaniesDB
    • AddressCountriesDB
    • PhoneFavorites2DB
    • Blazer Find Autofill
    • psysLaunchDB
    • Graffiti ShortCuts
    • MIDI Ring Tones
    • System MIDI Sounds
    • Saved Preferences
    • AddressStatesDB
    • AddressTitlesDB
    • Queries
    [*] Failed to backup 1 file(s)
    • PmTraceDatabase
      • Protocol Error: Handheld file could not be opened. (4004)
        • SYNCERR_FILE_NOT_OPEN
secondly
the PRL udate file , i try oppening it on my SD card but it says loading and the comes up and closes fast , that i cant do any thing , for which i have done some numbers of hard resets , can you please help me as i am really facing problems with the internet here
Waiting for your replies..
Anyways , problem grossed now, I first fell into a swimming pool with the phone , still it worked fine after drying the 755p, and worked for almost 5 days but later the phone fell from my hands and its screen struck the edge of a chair where it tottaly cracked inside , so KA BOOM. its tottaly down, keeping aside the display all the other parts are for sale , any one needs any part let me know ... by the way am waiting for the second piece from sadik . i am phoneless now.
sad episode... but seems hilarious the way you put it... KA BOOM... dont worry be happy, these things happen... but first swimming pool, then chair is a little too much...
