sougatadc
Display Problem In Nokia 6275
The display on my Nokia 6275 suddenly developed very fine horizontal lines. The resolution got worse with it. It is more apparent when the camera is on. The picture it displays is very bad, looks like a picture through a vga camera phone. Although the snap it takes is of same quality as before. I tried all types of software resets but to no avail.
Can anyone please help?
My dear friend, you must contact the Nokia service centre immediately.
I will try to send the set to any service centre as soon as possible. The problem is the lack of openness of CDMA handsets. If it was a GSM connection, I could have borrowed any handset from one of my friends for the time being and use it, but procuring a new handset only to send the faulty one to the service centre is a costly proposition. Anyways, as there is no other alternative, I will have to have at least an old handset for the time being.
Thank you for the suggestion, my friend 'Honest'.
