chet
Cdma Gsm Dual Phones
hi!can u guys suggest me a dual gsm+cdma handset?i did check out the spice d-88 for 7000, but can anyone tell me whether there is any service center in bombay?how would the chinese handsets be?i just want a good battery life?
My dear Chetan, if you want good battery life than you must go for Spice only. I'm not sure about the service centre location but their must be a service centre in Mumbai also.
