ACS
Using Spice D88n Micro Sd Card To Copy Contacts In Samsung Max!
Hi Guys..
My friend had a Micro SD Card previously being used with Spice D88n with a Back up of 850 Phonebook contacts.
He bought a Samsung Max as he was fed up with Spice problems. Another mistake made without thinking!
Anyways, we inserted the Micro SD card trying to see if we can copy the contacts to the Max.
To our surprise, when we went to Content Box, External Memory options, we could see the entire list of 850 contacts but had no clue what to do with it as there were no copy/move options to phone memory. (Although phone has only 500 contacts).
At some point of time we did come across all names with check boxes but couldn't figure out again how it happened.
BTW..
From the beginning Spice ASC has been saying that the Micro SD Card Phonebook Import/Export option is only for Spice & spice alone.
Then how was it possible that Samsung MAx was able to read the contacts stored/embedded in the Micro Card?
Is it because Samsung too Supports vcf format?)
Has anybody tried this or got a solution?
I think vcf is the same format as vCARD, by which we send contacts through SMS.
