jaypee
Samsung W299 - phone book transfer/retrieval problem
:signthankspin::signthankspin: Thank you Anuragz & ACS for the suggestion. :signthankspin::signthankspin:
I took help from our company IT person and he also did the same as suggested by you
i paid 12200 for the same in Vashi (Navi Mumbai)
I was on vacation & hence couldn't revert to you immediately
JP
Hi JP,
Kindly let us know from which shop in vashi (with address) u have purchased this phone at 12200/-
thanks
navin
Hi Navin, Manu, Bparesh
I bought the handset from Maru gallery in Sec 17 (this is diagonally opposite to McDonalds in Sec 17, vashi)
JP
I bought a new Samsung dual SIM handset (CDMA & GSM) W299 and it is good.
what is the cost of this handset ?
Yes Samsung W299 Is the Best DualSIM Handset I have seen considering the price.
I Am using it since 1 month. Bought in a week of its launch.
It is A BAR Model. Similarly like their Slider. All the features are same.
1000x5 Phonebook, 500CDMA/ 500GSM Sms Memory. + Your Sim Memories
Very good PCSYNC with their software.
It is a Touchscreen phone.
Actually its got a very easy interface (OS) once u know where the things are. Plus it is very customizable.
Its got 8GB expandable memory support. Dialing from CDMA or GSM is very easy. Plus one can decide which card will be your main card. (for speed-dial purpose only)
CONS :
its speaker may not be as loud as a chinese handset. just about ok.
and lastly it cannot hold a GSM call when somebody dials on CDMA and vice versa.
you can answer the other call though, but first one gets disconnected. which was not the case with my earlier chinese handset.
No information available on any of samsung websites.
COST: MRP 16999/- & I bought it for 12500/- all inclusive from a samsung shop.
All in all a good handset to buy and a descent price.
thanks
Amit
i visited the reliacne web world .. they quoted price as 14.5k in delhi.. can u suggest any place to get it for the price u quoted in delhi.. thanks in advance..
Samsung has a new web site where all new cdma mobiles are listed.
http://samsungcdma.org
Hope this helps
can opera mini or other games & softwares be installed in this phone?i've got m569 and that doesn't allow other applicatioons.
Hi All,
I purchased mobile and I don't see any problem with this mobile. Goes well.
May be I have the version of software on mobile: (I have the most updated version in this thread)
PRL:00010
S:W299.CC31
H:W299.08
GSM:SW.CA02
If anyone face any problem try updating the version. Even me too needs to check do they have any new version relaesed.
Thanks,
Gobinath
