hero
Lg 3100 Battery In Lg 2670 Possible?
Can I use the battery of LG 3100 reliance in LG 2670 reliance?
The 3100 battery says Lithium Ion Battery 3.7V, 950 mAh, LGIP-531E
The 2670 battery says Lithium Ion Battery 3.7V, 650 mAh, LGIP-A800
Yes! You can use the battery if it fits correctly in the battery socket and also the battery terminals are touching correctly with the same polarity. If the mAh (Milli Ampere hour) is high the talk time and standby time also increases.
Thanks a lot!
