reachanoop
Too Many Wrong Attempt To Find SPC For BlackBerry 7130E
Dear all
I am very new to this forum kindly help
I got one bb 7610e and was using unicdma and winhex to read the spc as bb 7610e was from sprint
As I was new I entered wrong spc many time, at last I found the correct spc code but now it is giving error “Usage of programming code exceed the limit”
Even when trying to connect to QPST it is giving error” online connection failure unspecified error”
Please help me resolve
Thanking you people in anticipation
Even I am new to the board But dont worry someone will come to ur rescue!
Best board for bb!
You have two problems
1) you need to scan memory thru UniCDMA and save it, then find SPC from winhex
2) you are using wrong version of QPST, you need QPST ver 2.7 Build 215
another way is to find OTKSL and use it for programming. OTKSL is One Time Key Subsidy Lock and its usually has limited number of usage. Each usage is counted. I have seen usage numbers from 8 to 255.
And some time only 1
better to get SPC and use it unlimited times
Also be carefull with 7130e, its spc may get corrupt ,
sir can you please tell how to find OTKSL
hitesh i have scaned the memory using unicdma and then saved it to a bin file then read spc thr winhex but was confused to use winhex( gathering number part ) at last got the right spc but when i insert that spc i get the error " “Usage of programming code exceed the limit”
and
secondly i tried using qpst 2.7 build 215 but the same error"online connection failure unspecified error”
please help
Find solution for corrupt SPC and smile..
Shoot me email on me@sadikk.com if u didnt find anything..
'sir ji get me out of this issue
the phone is getting connected to QPST
but i think i dnot know the spc
help me out
you are not getting your spc in win hex ? zip your all bin and mail me.
