ramtech
Please suggest on LED Monitor
Dear friends
I am planning to buy LED monitor for my pc.
20-23 inch size.
Should consume less power
Preferably with DVI-B input (or HDMI if possible but not mandate)
wide screen, should be able to view TV channels/movies in 16:9 format
Preferably want to buy from letsbuy.com(best prices with RCOMLB1 discount)
Have seen BenQ, Viewsonic, AOC, Dell.My preference is Samsung but not available on letsbuy.com
If best option is available on other online sources or in shops I will go for it ( dont mind paying few hundreds more for quality)
Please suggest me the best option
Thanks in advance
For your info only: 20" Samsung LED available for Rs. 6300/-, 18.5" LG LED available for Rs. 5550/- in Mumbai. NEC 21.6" TFT Wide Glossy available for Rs. 6095/- (Taxes extra)
i am using samsung 20 inch led for last 3 months. had bought it at 6800/- that time.
Dear friends
20-23 inch size.
Thanks in advance
I have seen this model on Letsbuy.com for Rs.8488
BenQ 21.5 Inch LED Full HD Monitor with DVI Port G2222HDL Black
Can any techie or others can give review or suggest is it a good model
Go for benq superb product.my cousin is using it since more then a year and also uses as his bedroom tv.
guys, am looking to buy one LED monitor for myself and am i a dilema between BenQ and Viewsonic, both are superb products, benQ have bit more clearity compared to viewsonic which is what i have heard from many users but i have found both much equal, cousin is very happy with his benq monitor.Any user of both these brands and their review would be appreciated.
Dear friends
20-23 inch size.
Thanks in advance
Ordered Dell ST2220L on 27th aug and recieved on 31st Aug for Rs.7649 after applying RCOMLB1 Code
22inch with 21.5 viewable size with Full HD resolution, 28watts max consumption, DVI,VGA and HDMI input
Actuall this model is not availabe in india I checked with Dell CC .They have told it is new model and it takes a months time to arrive in india.
Quality is good . I have connected my Philips dvd player to the monitor with HD(DVD has upscaling feature) and without HD (Video out)and there is a visible difference in the picture quality.
Colours are bright.Buttons are touch sensitive( actually there are no physical buttons)
only minus is you cannot view full screen of normal DVD wide screen movies (like moser bear provide dvd with 3movies) without streching.
either you can watch 4:3 format or stretched
Even i have dell ST222OM Monitor , its not LED, but quite Good HD support...
